Google Pixel 6 128GB - Coral
Quicklinx: GTRZWS00 Mfr#: GA02920-GB
Colours:
  • Android
A whole new Pixel, inside and out.
Pixel's very own powerhouse.
Tensor is the first chip made by Google, just for Pixel. It's the same chip used in Pixel 6 Pro, so it helps keep your phone running smoothly and efficiently.
Smarter chip for a smarter phone.
Incredibly intelligent machine learning helps you do things only Google lets you do, like instantly translate messages and videos without internet connection.
Powers our most powerful Pixel.
Up to 80% faster performance than Pixel 5, so apps load quicker and gaming is more responsive. Plus, it saves power so your battery lasts longer.
Adds a boost of camera magic.
Google Tensor’s custom image processor lets the all-new Pixel Camera capture fun times and starry nights exactly how you remember them.
The safest Pixel yet.
Google Tensor has an extra layer of protection and works with the new Titan M2 security chip to keep Pixel even more resilient to attacks.
An all-new camera for your best photos ever.
The all-new Pixel Camera has bigger sensors to help you capture more colour, more detail and 150% more light than Pixel 5. And with the ultrawide lens on the back, get even more of your world in the shot.
Fast, smart and personalised for you.
The all-day battery, reimagined interface and Smooth Display all adapt to the way you use your phone. Plus you get powerful 5G and enhanced Wi-Fi and Bluetooth.
Made to last. Made to be brilliant.
Ready for life's little accidents - Pixel 6 is built from Pixel's toughest Gorilla Glass yet, with up to 2x better scratch resistance than previous Pixel phones. And with IP68 protection, it can take on a little water and dust with no problems. It's just as durable as it is beautiful.
The display adapts to you - The battery-efficient 6.4" Smooth Display can adjust to what you're doing. Its high refresh rate means more responsive gaming and scrolling. And high brightness mode lets you watch and play in bright sunlight.
  • Pixel's very own powerhouse
  • An wonderful camera for your best photos ever
    The wonderful Pixel Camera has bigger sensors to help you capture more color, more detail, and 150% more light than Pixel 5. And with the ultrawide lens on the back, get even more of your world in the shot.
  • Fast, smart, and personalized for you
    The all-day battery, reimagined interface, and Smooth Display all adapt to the way you use your phone. Plus you get powerful 5G, and enhanced Wi-Fi and Bluetooth.
  • Pixel learns what you need, and puts it front and center
    At a Glance shows you the apps and info you need, right when you need it - like your boarding pass before your flight.
  • Speak fluent Spanish, or Japanese, or French
    Explore the world in other languages. Get your chats translated in real time, listen to podcasts with translated captions, and even use your camera to read signs in up to 55 languages. No internet needed.
  • Advanced security helps you feel safe every day
    Pixel's updated privacy and security features help ensure you, your personal data, photos, and everything on your phone stay safe.
Google Pixel 6 - Kinda Coral - 5G smartphone - 128 GB - GSM
5G smartphone
Manufacturer Model Number
GB7N6
Display
OLED display - 2400 x 1080 pixels - 6.4" - 411 ppi - (90 Hz) - 20:9 - OLED - HDR - fingerprint-resistant coating, Corning Gorilla Glass Victus (scratch resistant glass)
Google Tensor - with Titan M2 security
RAM 8 GB / 128 GB
Operating System
Android 12
Main Camera
50 Megapixel - f/1.85 - focus: automatic laser auto focus: - laser focus
Second Camera
12 Megapixel - ultra wide-angle lens - f/2.2
Front Camera
8 Megapixel f/2.0 - focus free
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
Wireless Interface
NFC, Wi-Fi 6, Bluetooth
Security Devices
Fingerprint reader (under display)
Connectors
USB-C
Wireless Charging Standards
Qi
Protection
Water-resistant, dust-resistant
Kinda Coral
74.8 mm x 8.9 mm x 158.6 mm
207 g
1 W/kg (head) , 1.38 W/kg (body)
Smartphone
GB7N6
Touch
Protection
74.8 mm
8.9 mm
158.6 mm
207 g
Body Colour
Kinda Coral
Body Material
Corning Gorilla Glass 6, tactile alloy frame
SAR Value
1.38 W/kg (body), 1 W/kg (head)
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
5G
Service Provider
Not specified
Operating System
Android 12
Intelligent Assistant
Google Assistant
Navigation
GPS, GLONASS, Galileo, QZSS, Dual Band GNSS
SIM Card Type
Nano SIM, Electronic SIM card (e-SIM)
SIM Card Qty
Dual-SIM
Input Device
Multi-touch
Communications
Data Transmission
EDGE, HSDPA, HSPA+, FDD-LTE, TDD-LTE, 5G NR FR1
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 6, Band 8, Band 19
3G UMTS Frequency
2100, 1900, 1700, 850, 800, 900, 800
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 14, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 29, Band 30, Band 32, Band 38, Band 39, Band 40, Band 41, Band 42, Band 46, Band 48, Band 66, Band 71
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700 PS, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 700d, FDD 2300 WCS, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, TDD 3500, TDD 5150, TDD 3600, FDD 1700 - 2110 AWS-3, FDD 600
5G NR Band
N1, n2, n3, n5, n7, n8, n20, n28, n38, n41, n66, n71, n77, n78, n40, n25, n12, n48, n30, n14
5G NR Frequency
FDD 2100, FDD 1900PCS, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, FDD 600, TDD TD 3700, TDD TD 3500, TDD 2300, FDD 1900, n12, TDD 3500, FDD 2300, n14
Wireless Interface
NFC, IEEE 802.11ax, Bluetooth 5.2
Phone Features
Sensors
Accelerometer, ambient light sensor, proximity sensor, barometer, magnetometer, gyro sensor, flicker sensor, spectral sensor
Security Devices
Additional Features
MIMO technology, Three microphones, Noise suppression, Fast Charging, ARCore, Google Cast, Trusty (Trusted Execution Environment), Private Compute Core, Android System Intelligence, Security hub
Media Player
Supported Digital Video Standards
H.264 AVC, H.265 HEVC
RAM
LPDDR5 SDRAM - 8 GB
Internal Memory Capacity
128 GB
Memory Interface
UFS 3.1
Front Camera
Sensor Resolution
8 Megapixel
Lens Aperture
F/2.0
Focus Adjustment
Focus free
Field of View (FoV)
84 degree(s)
Pixel Size
1.12 µm
Video Resolutions
1920 x 1080 (1080p) at 30 fps
Main Camera
Sensor Resolution
50 Megapixel
Sensor Size
1/1.31"
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Aperture
F/1.85
Field of View (FoV)
82 degree(s)
Pixel Size
1.2 µm
Focus Adjustment
Automatic
Laser Auto Focus
Digital Zoom
7x
Camera Modes
Panorama, portrait mode, Top Shot, Super Res Zoom, Frequent Faces, Cinematic Pan, Motion Mode, Real Tone, Face Unblur, Magic Eraser, Portrait Light, Motion autofocus, Astrophotography timelapse
HDR Mode
Live HDR+
White Balance
Custom
Light Source
Flash
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 40 fps
Stereo Recording, Audio zoom, laser detection auto focus (LDAF), Dual Exposure Controls, Octa PD Quad Bayer wide camera, 4K Timelapse with stabilisation, 4K Cinematic Pan video stabilisation, 4K Locked video stabilisation, 1080p Active video stabilisation
Second Camera
Sensor Resolution
12 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Field of View (FoV)
114 degree(s)
Pixel Size
1.25 µm
Lens correction
Display
OLED display
OLED
Diagonal Size
6.4"
Display Resolution
2400 x 1080 pixels
Display Format
Full HD+
Pixel Density
411 ppi
Aspect Ratio
20:9
Colour Depth
16.7 million colours
HDR
Refresh Rate
90 Hz
Contrast Ratio
1000000:1
Protection
Fingerprint-resistant coating, Corning Gorilla Glass Victus (scratch resistant glass)
Always-on display, Now Playing, Smooth Display (up to 90 Hz), High brightness mode, At a Glance
Connector Type
USB Type-C - 24 pin USB-C
4614 mAh
Fast Charging Technology
Power Delivery 3.0
Wireless Charging
Qi
Run Time Details
Mixed usage: up to 24 hrs , Mixed usage (Extreme Battery Saver): up to 48 hrs
IP68, HEARING AID M3/T3
SIM card removal tool, Quick switch adapter, USB-C to USB-C cable (1 m)
