Meet Pixel 4a, the helpful Google phone at a helpful price. It comes packed with all the things you want in a phone, for a lot less than you’d expect.
Capture the cosmos.
Night Sight on Pixel 4a can even take photos of the Milky Way. All it takes is one tap in Night Sight mode, and you’ll have the stars in your hand.
A camera that does the work for you.
Take great photos whether you’re under the stars or the sun. For difficult lighting, you can adjust the brightness and shadows separately with dual exposure controls. And Live HDR+ generates a preview of what your final image will look like before you take it.
A battery that lasts up to 24 hours.
Pixel 4a’s Adaptive Battery learns your favorite apps and reduces power to the ones you rarely use. This limits background battery usage and helps your phone last all day.
All the help you need, fast.
The new Google Assistant is the fast and easy way to get things done. Use it to control your phone, send texts, multitask on the go, and access your favorite apps. No typing or hunting through a folder on your Home screen. Just say, "Hey Google, open YouTube," and it’ll take you there instantly.
Superhero-level security chip.
The custom-made Titan M chip helps secure the operating system and sensitive data, like passwords and sensitive transactions. It’s an enterprise-grade security chip that was designed from the same ones used to protect Google Cloud data centers.
Ultra-smooth streaming, so you won't miss a beat
From gaming to watching your go-to shows, enjoy the content you love in crystal-clear HD. -
Share your 5G speed with friends
5G hotspot lets you send a superfast signal to friends, or speed up your laptop connection for easier working while on the go. -
Video calling that feels more like teleporting
With duo screen share in HD, you can read articles, watch live sports, and laugh together as if you were sitting in the same room. -
Beautiful moments, captured beautifully
The brilliant pixel camera with an ultra-wide lens and new goodies help you shoot and edit like the pros. -
Take photos in the dark
From low-light portraits to starry nights, night sight lets you capture all the details without the flash. -
Keep your magical moments vibrant
HDR+ automatically enhances color and lighting so the photos you take stay as vivid as you remember. -
See your portraits in the best light
If shadows get in the way of a great portrait, pixel drops in extra light to illuminate your subjects. -
Give your videos a cinematic look
Give your videos a cinematic look with super-smooth panning that's inspired by the equipment used in Hollywood movies. -
Adaptive battery
Adaptive battery learns your favorite apps and reduces power to the ones you rarely use, so your phone keeps its charge all day. -
A chip that has your back
The Titan M chip helps secure the OS and sensitive data, like passwords and transactions. -
Updates you don't have to remember
Automatically receive the latest security updates as soon as they're ready, so your phone stays safe and up to date with the latest software. -
One step ahead of the hackers
Pixel scans for incoming threats from calls, texts, emails, and links sent from other apps. It also scans over 100 billion apps a day to keep your phone safe.
- Google Pixel 4a with 5G - 5G smartphone - 128 GB - GSM
- Product Type
- 5G smartphone
- Manufacturer Model Number
- G025I
- Display
- OLED display - 2340 x 1080 pixels - 6.2" - 413 ppi - 19.5:9 - OLED - HDR
- Processor
- Qualcomm Snapdragon 765G 2.4 GHz (8-core)
- Graphics Accelerator
- Qualcomm ADRENO 620
- Memory
- RAM 6 GB / 128 GB
- Operating System
- Android 11
- Main Camera
- 12.2 Megapixel - f/1.7 - focus: automatic
- Second Camera
- 16 Megapixel - ultra wide-angle lens - f/2.2
- Front Camera
- 8 Megapixel f/2.0 - focus free
- Service Provider
- Not specified
- SIM Card
- Single-SIM - nano SIM, Electronic SIM card (e-SIM)
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth
- Security Devices
- Fingerprint reader
- Connectors
- USB-C
- Image Colour Disclaimer
- The displayed product image may be a different colour
- 74 mm x 8.2 mm x 153.9 mm
- 168 g
- Specific Absorption Rate (SAR)
- 0.94 W/kg (head) , 1.4 W/kg (body)
- 2-year warranty
- Product Type
- Smartphone
- G025I
- Form Factor
- Touch
- 74 mm
- 8.2 mm
- 153.9 mm
- 168 g
- Body Material
- Corning Gorilla Glass 3, soft-touch polycarbonate unibody
- SAR Value
- 1.4 W/kg (body), 0.94 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- Android 11
- Intelligent Assistant
- Google Assistant
- Navigation
- GPS, GLONASS, BeiDou, Galileo, QZSS
- SIM Card Type
- Nano SIM, Electronic SIM card (e-SIM)
- SIM Card Qty
- Single-SIM
- Input Device
- Multi-touch
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE, 5G NR FR1
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 6, Band 8, Band 19
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 800, 900, 800
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 14, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 29, Band 30, Band 32, Band 38, Band 39, Band 40, Band 41, Band 42, Band 46, Band 48, Band 66, Band 71
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700 PS, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 700d, FDD 2300 WCS, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, TDD 3500, TDD 5150, TDD 3600, FDD 1700 - 2110 AWS-3, FDD 600
- 5G NR Band
- N1, n2, n3, n5, n7, n8, n28, n41, n66, n71, n77, n78, n12
- 5G NR Frequency
- FDD 2100, FDD 1900PCS, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 700APT, TDD TD 2500, FDD AWS-3, FDD 600, TDD TD 3700, TDD TD 3500, n12
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 LE
- Bluetooth Profiles
- A2DP
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, barometer, magnetometer, gyro sensor, flicker sensor, spectral sensor
- Security Devices
- Additional Features
- Dual microphones, MIMO technology, Noise suppression, ARCore, 3 years of security and OS updates
Media Player
- Supported Digital Audio Standards
- Apt-X, LDAC, apt-X HD
- Clock Speed
- 2.4 GHz
- Processor Core Qty
- 8-core
Graphics System
- RAM
- LPDDR4X SDRAM - 6 GB
- Internal Memory Capacity
- 128 GB
Front Camera
- Sensor Resolution
- 8 Megapixel
- Lens Aperture
- F/2.0
- Focus Adjustment
- Focus free
- Field of View (FoV)
- 83 degree(s)
- Pixel Size
- 1.12 µm
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps
Main Camera
- Sensor Resolution
- 12.2 Megapixel
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Aperture
- F/1.7
- 77 degree(s)
- Pixel Size
- 1.4 µm
- Focus Adjustment
- Automatic
- Light Source
- Flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, 1920 x 1080 (1080p) at 120 fps, 1280 x 720 (720p) at 240 fps
- Electronic Image Stabiliser (EIS), Dual Pixel Phase Detect Auto-Focus (PDAF)
Second Camera
- Sensor Resolution
- 16 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- 107 degree(s)
- Pixel Size
- 1 µm
Display
- OLED display
- Technology
- OLED
- Diagonal Size
- 6.2"
- Display Resolution
- Display Format
- Full HD+
- Pixel Density
- 413 ppi
- Aspect Ratio
- 19.5:9
- Colour Depth
- 16.7 million colours
- HDR
- Contrast Ratio
- 100000:1
- Always-on display, Now Playing
- Connector Type
- USB Type-C - 24 pin USB-C
- Capacity
- 3885 mAh
- Fast Charging Technology
- Power Delivery 2.0
- HAC (Hearing Aid Compatible)
- Included Accessories
- SIM card removal tool, Quick switch adapter, 18W USB-C power adapter, USB-C to USB-C cable (1 m)
- Limited warranty - 2 years
