Pixel's extraordinary camera, Google Assistant built in and a battery that lasts all day - everything is possible with Google Pixel 3a.
The camera that does the work for you.
Night Sight
Lose the flash, get the shot. Night Sight gives you rich detail and colour, even in the dark.
Depth editor
Focus on what matters by adjusting the depth of field.
Colour pop
Make the colour pop, while softening the background in black and white.
Unlimited Storage
Save your photos and videos with free, unlimited storage in high quality with Google Photos.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots.
Night Sight
Lose the flash, get the shot. Night Sight gives you rich detail and color, even in the dark. -
Depth editor
Focus on what matters by adjusting the depth of field. -
Color pop
Make the color pop while softening the background in black and white. -
Long-lasting battery
The battery lasts up to 30 hours. Pixel's Adaptive Battery learns your favorite apps and reduces power to the ones you rarely use. -
Fast charging
Enjoy up to 7 hours of use on 15-minute charge. -
Make Google do it
Your Google Assistant can send texts, answers, and more. -
Know who is calling, and why
Get help with just a tap. Screen unknown calls, find out why they are calling, and see a real-time transcript of their response. -
Secured with Titan M
From passwords to OS, Google's custom made Titan M security chip helps protect your sensitive data.
- Google Pixel 3a - just black - 4G smartphone - 64 GB - CDMA / GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- G020F
- Display
- OLED display - 2220 x 1080 pixels - 5.6" - 441 ppi - 18:9
- Processor
- Qualcomm Snapdragon 670 2 GHz (8-core) - 64-bit
- Graphics Accelerator
- Qualcomm ADRENO 615
- Memory
- RAM 4 GB / 64 GB
- Operating System
- Android 9.0 Pie
- Main Camera
- 12.2 Megapixel - f/1.8 - focus: automatic
- Front Camera
- 8 Megapixel f/2.0 - focus free
- Service Provider
- Not specified
- SIM Card
- Single-SIM - nano SIM, Electronic SIM card (e-SIM)
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth
- Security Devices
- Fingerprint reader
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, USB-C
- Just black
- 70.1 mm x 8.2 mm x 151.3 mm
- 147 g
- Specific Absorption Rate (SAR)
- 0.72 W/kg (head) , 0.81 W/kg (body)
- Product Type
- Smartphone
- G020F
- Form Factor
- Touch
- 70.1 mm
- 8.2 mm
- 151.3 mm
- 147 g
- Body Colour
- Just black
- Body Material
- Polycarbonate
- SAR Value
- 0.81 W/kg (body), 0.72 W/kg (head)
Cellular
- Technology
- CDMA2000 1X / GSM / WCDMA (UMTS)
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Android 9.0 Pie
- Intelligent Assistant
- Google Assistant
- Navigation
- GPS, GLONASS, Galileo
- SIM Card Type
- Nano SIM, Electronic SIM card (e-SIM)
- SIM Card Qty
- Single-SIM
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, EV-DO, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM, 800 CDMA2000 1X, 1900 CDMA2000 1X
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 LE
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, barometer, magnetometer, gyro sensor, haptics sensor, Active Edge
- Security Devices
- Additional Features
- Dual microphones, MIMO technology, Android Sensor Hub, Noise suppression, Night Shift, ARCore, Google Lens, Titan M Security Module, Pixel Imprint sensor
Media Player
- Supported Digital Audio Standards
- Apt-X, LDAC, apt-X HD
- Clock Speed
- 2 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
Graphics System
- RAM
- LPDDR4X SDRAM - 4 GB
- Internal Memory Capacity
- 64 GB
Front Camera
- Sensor Resolution
- 8 Megapixel
- Lens Aperture
- F/2.0
- Focus Adjustment
- Focus free
- Field of View (FoV)
- 84 degree(s)
- Pixel Size
- 1.12 µm
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1280 x 720 (720p) at 30 fps, 640 x 480 (VGA) at 30 fps
Main Camera
- Sensor Resolution
- 12.2 Megapixel
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Aperture
- F/1.8
- 76 degree(s)
- Pixel Size
- 1.4 µm
- Focus Adjustment
- Automatic
- Camera Modes
- Portrait mode
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 30 fps, 1280 x 720 (720p) at 60 fps, 1920 x 1080 (1080p) at 120 fps, 1280 x 720 (720p) at 240 fps
- Electronic Image Stabiliser (EIS), dual pixel phase detection, Motion Auto Focus
Display
- OLED display
- Diagonal Size
- 5.6"
- Display Resolution
- Display Format
- Full HD+
- Pixel Density
- 441 ppi
- Aspect Ratio
- 18:9
- Colour Depth
- 16.7 million colours
- Contrast Ratio
- 100000:1
- Always-on display, Now Playing
- Connector Type
- USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
- Capacity
- 3000 mAh
- Included Accessories
- SIM card removal tool, Quick switch adapter, 18W USB-C power adapter, USB-C to USB-C cable (1 m)
