Google Nest Wifi Pro 3-Pack (2022) with Wi-Fi 6E
Quicklinx: H7PRWS00 Mfr#: GA03690-GB
  • IEEE 802.11n
13 In Stock
£315.84 ex VAT
£379.00 inc VAT
Google's fastest Wi-Fi yet.
Nest Wifi Pro. Fast, reliable Wi-Fi 6E coverage for life at home.
Mesh Wi-Fi router.
Mesh Wi-Fi routers act as a scalable system that provides coverage for your entire home, with consistently strong signals. Nest Wifi Pro also gives you the added reliability of Wi-Fi 6E speeds.
Wi-Fi 6E is the future of fast.
Faster than fast.
Wi-Fi 6E is twice as fast as the previous gen Wi-Fi 6, giving you combined speeds up to 4,2 Gbps to stream, work, and play with.
More space for networks to move.
Gives you access to the new 6 GHz band, which acts like an uncongested fast lane for your connected devices.
Stronger performance all around.
All this adds up to quicker, more responsive Wi-Fi for your video calls, games, AR/VR and more. Even your current devices will get faster.
Thoughtfully designed to perform.
Wi-Fi routers perform best when they're out in the open. So Nest Wifi Pro is designed to look good anywhere.
Higher quality. Lower impact.
Nest Wifi Pro is made with over 60% recycled materials based on product weight.
Built with Matter. So your devices work as a team.
Nest Wifi Pro is built with Matter, the new universal standard that simplifies smart home compatibility. It connects and controls all your Matter devices, so they will work seamlessly with Google Home.
A more reliable smart home network with Thread.
Thread is the universal technology for keeping all your smart home devices connected. Nest Wifi Pro has a built-in Thread border router to connect your Thread mesh network of smart devices to your Wi-Fi network. Your Thread-enabled network will be faster, use less energy and reach more places throughout and around your home.
The Google Home app. Designed for simplicity.
Control your Nest Wifi Pro whether you’re home or away. Use the Google Home app to check your network performance, keep track of connected devices, and more.
Welcome guests with their own network.
Create a separate guest network and password for guests so that you don't have to share yours. And if you see a device that doesn't belong, easily restrict access for unknown users on your network.
Parental controls included for safer online habits.
With the Google Home app, you can block access to certain websites and explicit content. Set parental controls like Wi-Fi schedules, Internet time outs and more – at no additional cost.
Automatic security updates to help keep you safe.
With secure booting and software updates, Nest Wifi Pro helps to protect your network from hacks or other unauthorised software.
Proactively monitors and fixes common issues itself.
If your speeds start to dip while streaming on movie night, your worries are gone before you know it. Nest Wifi Pro is designed to monitor your network, and solve common issues all by itself.
Pushes your coverage to the edge.
Nest Wifi Pro is designed to make sure that your connection is strong and consistent even at the edge of your network's coverage.
Knows how to optimise for performance.
Nest Wifi Pro automatically manages network performance and activity to prioritise things like video calls, help websites load quickly, and keep everything running smoothly.
  • Google's fast Wi-Fi
    Nest Wi-Fi Pro. Fast, reliable Wi-Fi 6E coverage for life at home.
  • Mesh Wi-Fi router
    Mesh Wi-Fi routers act as a scalable system that provides coverage for your entire home, with consistently strong signals. Nest Wi-Fi Pro also gives you the added reliability of Wi-Fi 6E speeds.
  • Faster than fast
    Wi-Fi 6E is twice as fast as the previous gen Wi-Fi 6, giving you combined speeds up to 4.2Gbps to stream, work and play with.
  • More space for networks to move
    Gives you access to the 6GHz band, which acts like an uncongested fast lane for your connected devices.
  • Stronger performance all around
  • Thoughtfully designed to perform
    Wi-Fi routers perform best when they're out in the open. So Nest Wi-Fi Pro is designed to look good anywhere.
  • Built with Matter
    Nest Wi-Fi Pro is built with Matter, the universal standard that simplifies smart home compatibility. It connects and controls all your Matter devices, so they will work seamlessly with Google Home.
  • A more reliable smart home network with Thread
    Thread is the universal technology for keeping all your smart home devices connected. Nest Wi-Fi Pro has a built-in Thread border router to connect your Thread mesh network of smart devices to your Wi-Fi network. Your Thread-enabled network will be faster, use less energy and reach more places throughout and around your home.
  • Welcome guests with their own network
  • Parental controls included for safer online habits
    With the Google Home app, you can block access to certain websites and explicit content. Set parental controls like Wi-Fi schedules, Internet time outs and more - at no additional cost.
  • Proactively monitors and fixes common issues itself
    If your speeds start to dip while streaming on movie night, your worries are gone before you know it. Nest Wi-Fi Pro is designed to monitor your network, and solve common issues all by itself.
  • Pushes your coverage to the edge
    Nest Wi-Fi Pro is designed to make sure that your connection is strong and consistent even at the edge of your network's coverage.
  • Knows how to optimize for performance
    Nest Wi-Fi Pro automatically manages network performance and activity to prioritize things like video calls, help websites load quickly, and keep everything running smoothly.
Google Nest Wifi Pro - Wi-Fi system - Wi-Fi 6E - desktop
Wi-Fi system - mesh
Enclosure Type
Desktop
Wi-Fi System Components
3 routers
Wi-Fi System Coverage
Up to 320 sq.m
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ax (Wi-Fi 6E), IEEE 802.11ac, Ethernet, Fast Ethernet, Gigabit Ethernet
Frequency Band
2.4 GHz / 5 GHz / 6 GHz
Data Transfer Rate
4.2 Gbps
Connected devices: 300
Scalable, band steering, QoS, device prioritisation, Matter compatibility, dual-stream (2x2), 4K UHD video streaming, secure boot, dual core CPU, parental control, guest access
IEEE 802.11s, IEEE 802.11k, IEEE 802.11v
Snow
11.7 cm x 8.5 cm x 13 cm
595 g
United Kingdom
Wi-Fi system - mesh - 2-port switch (integrated)
3 routers
Up to 320 sq.m
Enclosure Type
Desktop
Wireless, wired
Frequency Band
Data Transfer Rate
4.2 Gbps
Encryption Algorithm
WPA3
Wi-Fi Rating
AXE4200
Mesh Networking
1 x ARM
RAM
1 GB
Flash Memory
4 GB
Internet of Things (IoT)
Communications Technology
Bluetooth Low Energy (LE)
LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45
External power adapter - 22.5 Watt
Enclosure Colour
Snow
1 x network cable - 2 m
United Kingdom
11.7 cm
8.5 cm
13 cm
595 g
Type: Wi-Fi system
Connectivity: Wireless
Connectivity: Wired
Speed: 4.2Gbps
Protocol: IEEE 802.11a
Protocol: Fast Ethernet
Protocol: Ethernet
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: Gigabit Ethernet
Protocol: IEEE 802.11ax (Wi-Fi 6E)
Brand: Google
