Google Nest Stand and Cable Bundle
Quicklinx: GG2NWS00 Mfr#: GA02070-GB
Type: Security Accessory
Compatible With: Nest
£24.17 ex VAT
£29.00 inc VAT
The Google Nest Bundle including Stand & Cable
Keep your Google Nest Cam powered with the Google Nest Cam Stand Charger. The minimalist stand includes a magnetic connector and 3 m long cable - ideal for 24/7 camera recording.
Or you can simply use it to recharge your Nest Cam (battery).
  • Base diameter: 66 mm (2.58 in)
  • Height: 57 mm (2.24 in)
  • Weight: 285 g (10.05 oz)
  • Power cable Length: 3 m (10 ft)
  • Articulation: 0 to -45°
  • Ports and connectors: Stand with Nest Cam magnetic connector & Barrel connector for the power cable connected to the base of the stand
Google - charging stand
Charging stand - external
285 g
United Kingdom
Output connectors
1 x magnetic
AC power adaptor
Snow
6.6 cm x 6.6 cm x 5.7 cm
1-year warranty
Nest Cam
Snow
United Kingdom
1 x magnetic
AC power adaptor
Power cable 3 m
Indoor use, 0° to -45° adjustable angle
Limited warranty - 1 year
6.6 cm
6.6 cm
5.7 cm
285 g
Google Nest Cam
Brand: Google
