Google Nest Hub Max - Charcoal
Quicklinx: FCFHWS00 Mfr#: GA00639-GB
Type: Smart Display
Colours:
39 in stock
£182.50 ex VAT
£219.00 inc VAT
Hey Google, make it easier
Google Nest Hub Max helps your busy family stay in touch and on track. And with the Google Assistant 1, you don’t have to lift a finger. Just use your voice.
Keep everyone connected.
Hey Google, call Mum. Make video calls to friends and family. And leave video messages for each other on Nest Hub Max.2
Stay in touch and in sight.
Multi-task while you make video calls. With auto-framing, the camera keeps you in view as you move around the room.
The ultimate digital picture frame.
See your latest and greatest from Google Photos – automatically.3 They’ll all look beautiful on the 10-inch HD screen.
Check in on home when you’re away.
Keep an eye on things at home with the built-in Nest Cam4. Check in from your phone and get motion and sound alerts. And with a Nest Aware subscription, you’ll also get continuous video recording.
Make your smart home even smarter.
Use your voice to control your Nest thermostat, smart lights, TVs, and hundreds of other compatible smart home devices5. See them all on one screen – no more opening app after app.
Watch what you want, when you want.
With Chromecast built in, stream movies and TV shows from services like Google Play Movies, Netflix, Now TV and more.6
The Google Assistant shows you all you need to know.
Nest Hub Max automatically shows your calendar, commute, reminders and more.7
1 Requires an Internet connection.
2 To make video calls and leave video messages, Google Duo accounts required for you and call recipient
3 To see personal photos, Google Photos is required.
4 Night Vision not supported.
5 Compatible smart devices required.
6 Subscriptions may be required for some content.
7 Personalised features require additional enrolment and setup.
  • See who's at the door
    Google Nest Hub works with the Nest Hello video doorbell to show you who's at the front door, so you never miss friends, family, or package deliveries. Just say, "Hey Google, show me the front door. "
  • Get the inside scoop
    What are the kids doing? Is Spot on the sofa again? Google Nest Hub works with Nest Cam Indoor to let you cheque in on any room, so there are no surprises. Just say, "Hey Google, show me the living room. "
  • Cosy up
    Set the temperature on your Nest Learning Thermostat using your voice. Just say things like, "Hey Google, make it warmer. " You can also adjust the temperature right on the Google Nest Hub screen.
  • Keep an eye on outside
    See what's happening outside by asking things like, "Hey Google, show me the backyard. " Google Nest Hub works with Nest Cam IQ outdoor to show you what your kids or furry friends are up to.
Google Nest Hub Max - smart display - wireless
Smart display - 2.1-channel
Speaker Type
Active
Amplifier Output Power
50W
Amplifier
Integrated
Display
LCD - 10" - 1280 x 800 - touch screen
Camera
6.5 Megapixel
Wi-Fi, Bluetooth
Platform
Belkin WeMo, Hue, Nest
Intelligent Assistant
Google Assistant - direct
Streaming Services
YouTube, Pandora, Spotify, Google Play Movies, Google Maps, Hulu, HBO NOW, Chromecast
Speaker Details
Speaker - stereo x 2 - 10 Watt - active , Speaker - subwoofer - 30 Watt - active
Charcoal
25.01 cm x 10.123 cm x 18.255 cm
1.32 kg
Microphone
2 microphones array
Sensors
Ambient light sensor
Enclosure Colour
Charcoal
Speaker System
Speaker Type
Active
Amplifier
Integrated
Audio Amplifier Output Power
50W
IEEE 802.11b/g/n/ac, Bluetooth 5.0
Internet Streaming Services
Display
Camera
6.5 Megapixel
Internet of Things (IoT)
Platform
Communications Type
Cloud
Intelligent Assistant Compatible
Google Assistant
Voice Control
Direct
Speaker System Details
Speaker Details
Driver Details
Speaker: 2 x tweeter driver , Speaker: subwoofer driver
AC power adaptor
Power Source
AC power adapter
30 Watt
25.01 cm
10.123 cm
18.255 cm
1.32 kg
2 year
Type: Smart Display
Brand: Google
Price Range Ex VAT: 150 - 300
