Google Nest Hub - Charcoal
Quicklinx: FPB2WS00 Mfr#: GA00515-GB-BT2
1 on order, delivery delayed
Unique voucher code
The unique voucher code used to access this page is only valid for one order. You can order multiple (max 6 per customer) but this must be done as part of the same order.
Google Nest Hub brings you visual help for any moment at home. With the Google Assistant built-in, use your voice to view your latest events and reminders and to control smart devices from a single dashboard.
Help at a glance.
Google Nest Hub provides help at a glance in any room at home. With the Google Assistant built-in, always see your best and latest shots from Google Photos. Plus, view and control your compatible connected devices from a single dashboard. Simply use your voice to watch YouTube and play songs from YouTube Music. You can even get your calendar, commute, answers from Google, and more.
Relive your memories with Google Photos
Google Nest Hub is the ultimate digital picture frame. With Recent Highlights from Google Photos, see your best and latest pictures automatically–no manual updates required.
Control your connected home
View and control compatible lights, plugs, cameras, TVs and other devices from a single dashboard. Works with Nest devices like thermostats and security cameras along with hundreds of smart devices from popular brands.
Play videos and songs from YouTube
Watch YouTube and play songs and music videos from YouTube Music. Plus, listen to Spotify, Deezer and your favourite radio stations.
Get hands-free help from the Google Assistant
See your personalised schedule, commute, reminders and more with Voice Match. Plus, get visual answers from Google and watch helpful videos from YouTube.
Designed for any room at home.
Google Nest Hub fits naturally in any room at home. With Ambient EQ, Google Nest Hub adjusts to match the colours and lighting in its environment, so photos on Google Nest Hub seamlessly blend in with your home decor. Choose from four beautiful hues available from the Google Store —Chalk, Charcoal, Aqua and Sand—designed to fit in, or stand out if that’s your style.
Tech specs
Dimensions & weight: 178 mm W, 118 mm H
Display: 177.8 mm (7 in) LCD touch screen
Speaker: Full range speaker
Sensors: Light sensor
Connectivity: Wi-Fi and Bluetooth support
Power: 15 W adaptor
Ports: DC power jack
Requirements: Wi-Fi-enabled supported device
  • Control your connected home in one view
    Voice-control thousands of devices, from lights and cameras to TVs and more, all from a single dashboard.
  • See immersive answers from Google
    Just ask your assistant and get rich, visual answers about recipes, local businesses, sports, and more.
Google Home Hub - smart display - LCD 7" - wireless
Smart display - LCD 7"
Media Content Source
Chromecast
United Kingdom
Speaker Type
Active
Amplifier
Integrated
Display
LCD - 7" touch screen
IEEE 802.11b/g/n/ac, Bluetooth
Intelligent Assistant
Google Assistant - direct
Streaming Services
Chromecast
Charcoal
17.85 cm x 6.73 cm x 11.8 cm
480 g
Chromecast
Microphone
2 microphones array
Enclosure Colour
Charcoal
United Kingdom
Speaker System
Speaker Type
Active
Max Output Level (Max SPL)
80 dB
Multiroom
Amplifier
Integrated
IEEE 802.11b/g/n/ac, Bluetooth 5.0
Internet Streaming Services
Chromecast
Display
Internet of Things (IoT)
Google Assistant
Voice Control
Direct
Speaker System Details
Driver Details
Speaker: full-range driver
Power Source
AC power adapter
15 Watt
17.85 cm
6.73 cm
11.8 cm
480 g
