Google Nest Cam (outdoor or indoor, battery) - Pack of 2
Quicklinx: GG2LWS00 Mfr#: GA01894-GB
Hurry, only 1 left in stock!
£249.17 ex VAT
£299.00 inc VAT
Express delivery Order within the next 10 hours for delivery tomorrow
Know more. Outside or in.
Who’s in the garden? What’s the dog up to? Nest Cam is battery powered, so it goes wherever you need it most, outside or in. It knows the difference between people, animals and vehicles, so you can get the alerts that are important to you. Listen and speak through the camera, right from the Google Home app. Check in anytime with 24/7 live view. If you miss a notification, it includes 3 hours of event video history so you can go back and see what happened. And it’s easy to install yourself – no outlet or wires required.
Check in on what matters.
Nest Cam shows you what’s happening at home, and alerts you of important activity, no matter where you are. It can tell the difference between a person, animal and a vehicle. And if you miss something, go back and see what happened with 3 hours of free event video history in the Google Home app.
Get alerts and take action.
Nest Cam helps you know that things are OK at home. If something happens, it alerts you, so you can decide to take action right from the Google Home app. You can also talk and listen from anywhere through the camera’s built-in microphone and speaker.
Outdoors or indoors. Rain or shine.
With no wires and a range of accessories, Nest Cam is designed to go anywhere. It’s battery powered and weather resistant. Put it on the exterior of your house to check in on the yard. Or put it inside your home to check in on the dog or your family. An available stand makes it easy to set up wherever you want (sold separately)
Protects your privacy.
Nest Cam uses encrypted video, two-step verification, and enhanced security through your Google Account to help protect your privacy. And a green LED light lets you know when the camera is processing or streaming video.
Home & Away Routines give you the option of automatically turning your camera off when you’re home, so no video is streamed or recorded until you leave.
See clearly in any light.
HDR helps you see key details in bright, high-contrast sunlight, and night vision gives you a clear image even in low light and darkness.
Go back in time.
If you miss a notification or other event, you can go back and see what happened with 3 hours of free event video history. And you can always add a Nest Aware subscription to get up to 60 days of video history. (Extra subscription required)
Choose the areas that matter most.
Activity Zones let you define specific areas and get notified when something happens there. So you only get alerted about things that are important to you.
Wi-Fi problems? Not a problem.
If your Wi-Fi goes down or there’s a power outage, Nest Cam will automatically store up to one hour of recorded events in its memory. When things are up and running again, you’ll be able to see exactly what happened.
Install it yourself.
Wire-free installation is easy. You can put Nest Cam almost anywhere you want, outside or in. And since it’s battery powered, you don’t need to install it near an outlet.
Better together.
Nest Cam works with Nest Hub to let you see your Nest Cam live feed on the Nest Hub display. You can also zoom in to get a closer look.
2 Year Warranty
  • Get alerts for what matters
    Who's in the garden? Did the newspaper already arrive? With 24/7 live view and with three hours of free event-based recording, Nest Cam helps you look after your home.
  • Indoors or outdoors, rain or shine
    Nest Cam is battery-powered, which means installation is as easy as hanging a picture frame. Get one Nest Cam or a few to put inside or outside, anywhere you want to check in from.
  • Snap it into place anywhere
    Battery-powered installation is easy. You can put Nest Cam almost anywhere that you want, outside or in. And as it's battery-powered, you don't need to install it near an electrical socket.
  • Weather the elements
    Nest Cam is battery-powered and weather-resistant, and you can recharge it at any time.
  • Look closer to see details
    See something? Zoom in to get a closer look. You can save and share clips from your phone, too.
  • Talk through the camera
    Two-way talk helps you easily interact with delivery persons or other visitors through a built-in speaker and mic.
  • Stay connected
    If your Wi-Fi goes down or there's a power outage, Nest Cam will automatically store up to one hour of recorded events in its local memory. When things are up and running again, you'll be able to see exactly what happened.
Google Nest Cam - network surveillance camera
Network surveillance camera - fixed - outdoor, indoor - weatherproof
Packaged Quantity
2 (specifications are for single item)
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
Camera Mount Type
Wall mount
8.3 cm x 8.3 cm
398 g
Snow
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
1/2.8" - 2 MP
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Platform
Nest
Intelligent Assistant
Google Assistant
1 - charging cable - 1 m
Pet Detection, full duplex audio, Live Streaming, High Dynamic Range (HDR), Vehicle Detection, secure boot, People Detection, 110-degree motion detection angle, magnetometer sensor
Environmental Parameters (operating)
-20 °C - 40 °C
Packaged Quantity
Audio Support
Camera Mount Type
Wall mount
Wireless
8.3 cm
8.3 cm
398 g
United Kingdom
Camera
Colour - Day&Night - fixed - outdoor, indoor - weatherproof
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Digital Zoom
6
Infrared LEDs
6
Infrared Distance
6.1 m
Frame Rate (max)
Image Sensor
2 MP 1/2.8"
Lens Construction
Diagonal Field of View (degree)
130
Network Interface
Network Protocols
TLS, SSL
4 wall anchors, 2 magnetic mounts, 2 wall plates, 4 wall screws
1 x charging cable - 1 m
AES-128, IP54, WEP, WPA, WPA2, WPA3
Snow
Power adapter - external
1 Lithium Ion 6 Ah
Internet of Things (IoT)
Platform
Nest
Communications Technology
Bluetooth Low Energy (LE)
Google Assistant
-20 °C
GG2L Google Nest Stand and Cable Bundle In Stock £24.17
GG2L Google Nest 5m Power Cable In Stock £24.17
Type: Indoor Camera
Type: Outdoor Camera
Brand: Google
