Google Nest Cam (2021) with floodlight (wired)
Quicklinx: GG2MWS00 Mfr#: GA02411-GB
Type: Outdoor Camera, Floodlight
£215.84 ex VAT
£259.00 inc VAT
Know more.
Spot what matters.
A floodlight meets a security camera meets intelligence.
Shine a brighter light on what’s happening.
Built-in intelligent alerts help you know and see what's relevant. Tell the difference between people, vehicles, and animals.
Light a path when you need it.
Two LED lights and 180° motion detection add brightness and flexibility, so virtually nothing will go undetected.
Check in on your home in crisp HDR.
Use the Google Home app to see what’s happening near your floodlight 24/7 in 1080p HDR video. Night vision helps you see in low light.
Look back with ease.
Need to review something you missed? Look back with up to three hours of event video history included.
Make the floodlight yours.
Create routines and adjust brightness, sensitivity and how long the light stays on.
Quickly take action.
Turn it on with your voice and talk through the camera if you need to.
Keep your data safe and secure.
Two-step verification enhances security, and the green LED light lets you know that it’s recording.
2 Year Warranty
  • Shine a brighter light on what's happening
    The built-in intelligence of Nest Cam helps you stay aware of important activity. It can automatically turn on the lights, as well as send you an alert.
  • Light a path when you need it
  • Check in on your home in crisp HDR
    Use the Google Home app to see what's happening near your floodlight 24/7 in 1080p HDR video. Night vision helps you see in low light.
  • Look back with ease
    Need to review something you missed? Look back with several hours of event video history included.
  • Make the floodlight yours
    Home security shouldn't be one size fits all. Set up the floodlight to fit your home and your schedule.
  • Quickly take action
    Know more about what's happening with relevant alerts. If you get an alert that an animal, vehicle, or person is near, you can talk through the camera to help drive them away.
Google Nest Cam (2021) with Floodlight (Wired)
Network surveillance camera - fixed - outdoor - weatherproof (IP54)
Packaged Quantity
1
Audio
Yes; built in high quality speaker and microphone, 2-way audio capacity with noise cancellation
Camera Mount Type
Wall; fixed. Replaced existing wired floodlight, mounts onto an electrical box
Dimensions
Camera: 8.3cm (L) x 8.3cm (D) , Floodlight: 16.5cm (L) x 31.5cm (W) x 9.3cm (H)
Camera: 398g, Floodlight: 1165g
Snow
Connective Technology
Wireless
Camera
Colour: day and night , 1/2.8" megapixel sensor, 6x digital zoom, 130° diagonal field of view, 16:9 aspect ratio
Max Resolution
1080p
Max Frame Rate
30fps
Motion Detection
Yes. Camera: Single motion sensor, 110° horizontal field of view, up to 7.5m. Floodlight: Two motion sensors, 180° horizontal field of view, up to 7.5m
Video modes
1080p/30fps, HDR, 24/7 live view, night vision with HDR, H.264 encoding
Wireless
802.11a/b/g/n (2.4GHz) Wifi - WEP,WPA,WPA2,WPA3 encryption supported - Bluetooth Low Energy (BLE)
Platform
Google Nest
Intelligent Assistant
Google Assistant and Alexa-enabled devices
N/A
2-year limited warranty (details in box)
-20°C to 40°C
Lighting
Two Lights with adjustable brightness: up to 2400 lumens brightness, 4000k colour temp.
Packaged Quantity
1
Type: Floodlight
Brand: Google
