Meet Nest Audio. Hear music the way it should sound, with crisp vocals and powerful bass that fill the room. Just say, "Hey Google" to play your favorite songs from the streaming services you use most or get help. And create a home audio system with your other Nest speakers, just like that.
It’s all about sound.
Just say, "Hey Google, play some music," and crisp vocals and powerful bass fill the room. Nest Audio is 75% louder than the original Google Home, with 50% stronger bass. Play your favorite music, podcasts, and audiobooks from the streaming services you use most. Nest Audio adapts to your environment and whatever you’re listening to, so music sounds better. And news, podcasts, and audiobooks sound even clearer.
Nest Audio works better with two
Why buy two Nest Audios:
- Pair two Nest Audio speakers for stereo sound
- Listen, from room to room to room - Nest speakers work together, so that you can create your own audio system. You can even say, "Hey Google, move my music to the bedroom speaker," and it follows you.
- Use your Nest speakers as an intercom and chat from room to room
- Just say, "Hey Google" to broadcast messages on every Nest speaker and display in the house
Music here. Music there. Music everywhere.
Create a home audio system that fills your home with sound. Listen to music in stereo sound, or hear it all around the house. You can even say, "Hey Google, move my music to the bedroom speaker," and it follows you. Nest Audio works together with your other Nest speakers and displays, Chromecast-enabled devices, or compatible speakers. And it’s easy to set up.
Huge help around the house.
You can say things like, "Hey Google, set a timer for 5 minutes" and get help even faster. Ask Google about the weather, news, sports scores, or almost anything. Hear your schedule. Make Duo calls. And even turn on the lights or turn up the heat. All with your voice.
Thoughtfully designed. Environmentally sound.
Inspired by your home, Nest Audio’s colors, size, and shape fit beautifully into any room. It’s also designed with the environment in mind. The enclosure is made from 70% recycled plastic.
Designed to protect your privacy.
Nest Audio comes with privacy built in. You can delete your Assistant history by saying, "Hey Google, delete what I just said." Or to turn off the mic, just use the switch on the back.
Control it all with your voice.
It’s easy to control your music and media. Just use your voice, the Google Home app, or your Nest displays. And you can set up speaker groups and stereo sound in the Google Home app.
Connect with family and friends.
Nest Audio helps you stay in touch. Just say, "Hey Google" to broadcast messages on every Nest speaker and display in the house. Use your Nest speakers as an intercom and chat from room to room. And make audio calls with Duo.
Make it family-friendly.
Downtime helps your family disconnect from technology during dinner, bedtime, or special moments. With family-friendly filters, you can block access to music with explicit lyrics and control video services.
Rich, full sound
With Nest Audio's woofer, tweeter, and tuning software, crisp vocals and powerful bass fill your room. Nest Audio is 75% louder than the original Google Home and has 50% stronger bass. -
Clear audio
Nest Audio adapts to your environment and whatever you're listening to. So music sounds better. And news, radio, and audiobooks sound even clearer. -
Stream your favorites from your favorites
Just ask Google to play songs, playlists, podcasts, and audiobooks from popular streaming services. -
Music here, there, and everywhere
Fill your home with sound from all your Nest speakers and displays. And broadcast messages, chat between rooms, and make calls. -
Privacy built in
Nest Audio is designed to protect your privacy. You can delete your history by saying, "Hey Google, delete what I just said." To physically turn off the microphones, slide the mic switch on the back to show orange.
- Google Nest Audio - smart speaker
- Product Type
- Smart speaker
- Speaker Type
- Active
- IEEE 802.11b/g/n/ac, Bluetooth
- Intelligent Assistant
- Google Assistant - direct
- Streaming Services
- Chromecast
- Chalk
- 12.4 cm x 7.8 cm x 17.5 cm
- 1.2 kg
- Product Type
- Smart speaker
- Voice Match technology
- Light
- LED lights
- Hands-Free Function
- Microphone
- 3 microphones array
- Sensors
- Touch sensor
- Enclosure Colour
- Chalk
- Enclosure Material
- 70% recycled plastic
Speaker System
- Speaker Type
- Active
- Amplifier
- Integrated
- IEEE 802.11b/g/n/ac, Bluetooth 5.0
- Internet Streaming Services
- Chromecast
- Controls
- Mute microphone
- App-Controlled
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Integrated
- Google Assistant
- Voice Control
- Direct
Speaker System Details
- Driver Details
- Woofer driver , Tweeter driver
- Included Accessories
- Power adapter
- Power Source
- AC power adapter
- Cord Length
- 1.5 m
- 30 Watt
- 12.4 cm
- 7.8 cm
- 17.5 cm
- 1.2 kg
