GO Lamp for ET-LAV200. Lamp module for PANASONIC PT-VW430/PT-VX500/PT-VW435N/PT-VX505N projectors. Type = UHM. Power = 280 Watts. Lamp life (Hours) = 2500 STD/4000 ECO. Now with 2 years warranty.
- GO Lamps projector lamp
- Product Type
- Projector lamp - UHM - 280 Watt
- OEM Manufacturer Lamp Equivalent
- Panasonic ET-LAV200
- Bulb life cycle
- 2500 hour(s) (standard mode) / 4000 hour(s) (economic mode)
- 306 g
- 2-year warranty
- Designed For
- Panasonic PT-VW430E, VW430EA, VW430U, VW435NU, VX500E, VX500EA, VX500U, VX505NEA, VX505NU
- Product Type
- Projector lamp
- 306 g
Lamp
- UHM
- Capacity
- 280 Watt
- Life Cycle
- Limited warranty - 2 years
- Designed For
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
9WSS 046413 Condition: Customer return - item has been opened but is in excellent condition Item is not in original packaging. |
£31.54 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
