GO Lamp for AJ-LT91. Lamp module for LG RD-JT91 projectors. Type = NSH. Power = 200 Watts. Lamp Life = 2000 Hours. Alt part code = 6912B22008A.Now with 2 years warranty.
- GO Lamps projector lamp
- Product Type
- Projector lamp - NSH - 200 Watt
- OEM Manufacturer Lamp Equivalent
- 6912B22008A, AJ-LT91
- Bulb life cycle
- 2000 hour(s)
- 2-year warranty
- Designed For
- LG RD JT90, JT91, JT92
- Product Type
- Projector lamp
Lamp
- NSH
- Capacity
- 200 Watt
- Life Cycle
- 2000 hour(s)
- Limited warranty - 2 years
- Designed For
