Product
Brand
Gigabyte Z97X-GAMING-G1-WIFI S1150 Z97 4xDDR3 8xUSB3.0 6xUSB2.0 ATX
Quicklinx: 9FX5WS00 Mfr#: GA-Z97X-GAMING-G1-WIFI-BK
  • Bluetooth 4.0
  • IEEE 802.11n
GA-Z97X-Gaming G1 WIFI-BK Intel® Z97 Chipset
  • Extended server level 168 hour durability Test
  • Supports 4th and 5th Generation Intel® Core™ processors
  • Onboard Creative Sound Core3D™ quad-core audio processor
  • AMP-UP Audio technology with exclusive Upgradable OP-AMP
  • Audio Noise Guard with LED path lighting
  • Dual DAC-UP USB ports
  • Gold plated display and audio ports
  • High end Nichicon audio capacitors
  • Killer™ E2200 and Intel gaming networking
  • Bluetooth 4.0+867Mbps 11AC dual band WIFI card
  • Extreme gaming 4-way graphics support
  • SATA Express support for 10 Gb/s data transfer
  • Water block thermal design with G1/4 threaded fittings
  • Long lifespan Durable Black Solid caps
  • APP Center including EasyTune™ and Cloud Station™ utilities
  • GIGABYTE UEFI DualBIOS™
Gigabyte GA-Z97X-Gaming G1 WIFI-BK - Black Edition - 1.0 - motherboard - ATX - LGA1150 Socket - Z97
Motherboard - ATX
Chipset Type
Intel Z97 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC
Storage Ports
10 x SATA-600 (RAID), 1 x SATA Express port
USB / FireWire Ports
6 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
Max Allocated RAM Size
1 GB
Audio
HD Audio (6-channel)
LAN
Bluetooth, 2 x Gigabit Ethernet, 802.11a/b/g/n/ac
Motherboard - ATX
Chipset Type
Intel Z97 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2666 MHz (O.C.), 2600 MHz (O.C.), 2500 MHz (O.C.), 2400 MHz (O.C.), 2200 MHz (O.C.), 2133 MHz (O.C.), 2000 MHz (O.C.), 1866 MHz (O.C.), 1800 MHz (O.C.), 3000 MHz (O.C.), 3100 MHz (O.C.), 3200 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1 GB
Audio
Audio Codec
High Definition Audio
LAN
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 3.0 x16 (x16 mode (x8 mode if all PCI Express 3.0 x8 slots are occupied)) , 2 x PCIe 3.0 x16 (x8 mode) , 3 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin SATA, 1 x SATA Express port - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , Marvell 88SE9172: SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1
RAID Features
Intel Smart Response Technology
2 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 1 x HDMI , 6 x USB 3.0 , 1 x DisplayPort , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK , 1 x PS/2 keyboard / mouse , 1 x DVI-I
Internal Interfaces
6 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
Q-Flash, NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, NVIDIA 2-way SLI Technology Support, On/Off Charge, Intel Smart Response Technology, Fanless Design Heatsink, NVIDIA 4-way SLI Technology Support, AMD CrossFireX technology support, AMD 3-way CrossFireX technology support, Intel Rapid Start Technology, Intel Smart Connect Technology, AMD 4-way CrossFireX technology support, GIGABYTE OPT Fan Support, GIGABYTE AMP-UP Audio, Gold Plated Audio Hardware, Black Solid Capacitors, GIGABYTE USB DAC-UP, upgradable OP-AMP, GIGABYTE Smart Switch, TI Burr Brown OPA2134 operational amplifier
Software Included
Norton Internet Security, @BIOS, EasyTune, Cloud Station, GIGABYTE EZ Setup, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, Smart TimeLock, SBX Pro Studio, GIGABYTE Fast Boot
Plug and Play, ACPI 5.0
30.5 cm
24.4 cm
