Gigabyte Z77-DS3H Motherboard combine a host of new and exciting technologies with the latest Intel Z77 Express Chipset, creating a unique range of motherboard designs that harness the outstanding performance of the new 3rd generation Intel Core processors. With an exclusive Gigabyte 3D BIOS (Dual UEFI), UD4 Classic technology and unique EZ Set Up uilities, Gigabyte Z77-DS3H Motherboard ensure outstanding system absolute control, with additional features that ensure an unrivalled experience on your next PC build.
- 3D Bios
- 3rd Generation Intel Core Processors support
- PCI-E 3.0 Support
- Intel Rapid Start Technology
- Gigabyte Ultra Durable 4 Classic
- Gigabyte EZ Smart Response
- Onboard mSATA
- Gigabyte 333 Onboard Acceleration
- Gigabyte On/Off Charge
- Lan Optimizer
- Multi-Display Support with CrossFireX
- 3 Years Manufacturers Warranty
- CPU: Support for Intel Core i7 processors/Intel Core i5 processors/ Intel Core i3 processors/Intel Pentium processors/Intel Celeron processors in the LGA1155 package, L3 cache varies with CPU
- Chipset: Intel Z77 Express Chipset
- Memory: 4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory, Dual channel memory architecture, Support for DDR3 2400(OC)/1600/1333/1066 MHz memory modules, Support for non-ECC memory modules, Support for Extreme Memory Profile (XMP) memory modules
- Onboard Graphics Integrated Graphics Processor: 1 x D-Sub port, 1 x DVI-D port, supporting a maximum resolution of 1920x1200, 1 x HDMI port, supporting a maximum resolution of 1920x1200
- Audio: Realtek ALC887 codec, High Definition Audio, 2/4/5.1/7.1-channel, Support for S/PDIF Out
- LAN: Atheros GbE LAN chip (10/100/1000 Mbit)
- Expansion Slots: 1 x PCI Express x16 slot, running at x16 (PCIEX16), 1 x PCI Express x16 slot, running at x4 (PCIEX4), 2 x PCI Express x1 slots, 2 x PCI slots
- Multi-Graphics Technology: Support for AMD CrossFireX technology
- Storage Interface Chipset: 2 x SATA 6Gb/s connectors (SATA3 0/1) supporting up to 2 SATA 6Gb/s devices, 3 x SATA 3Gb/s connectors (SATA2 2/3/4) supporting up to 3 SATA 3Gb/s devices, 1 x mSATA connector, Support for RAID 0, RAID 1, RAID 5, and RAID 10
- USB Chipset: Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB header), Up to 8 USB 2.0/1.1 ports (4 ports on the back panel, 4 ports available through the internal USB headers)
- Internal I/O Connectors: 1 x 24-pin ATX main power connector, 1 x 4-pin ATX 12V power connector, 2 x SATA 6Gb/s connectors, 3 x SATA 3Gb/s connectors, 1 x mSATA connector, 1 x CPU fan header, 3 x system fan headers, 1 x front panel header, 1 x front panel audio header, 1 x S/PDIF Out header, 2 x USB 2.0/1.1 headers, 1 x USB 3.0/2.0 header, 1 x Clear CMOS jumper, 1 x serial port header, 1 x Trusted Platform Module (TPM) header
- Back Panel Connectors: 1 x PS/2 keyboard/mouse port, 1 x D-Sub port, 1 x DVI-D port, 1 x HDMI port, 4 x USB 2.0/1.1 ports, 2 x USB 3.0/2.0 ports, 1 x RJ-45 port, 3 x audio jacks (Line In/Line Out/Microphone)
- I/O Controller: iTE I/O Controller Chip
- H/W Monitoring: System voltage detection, CPU/System temperature detection, CPU/System fan speed detection, CPU overheating warning, CPU/System fan fail warning, CPU/System fan speed control
- BIOS: 2 x 64 Mbit flash, Use of licensed AMI EFI BIOS, Support for DualBIOS, PnP 1.0a, DMI 2.0, SM BIOS 2.6, ACPI 2.0a
- Warranty: 3 Years Manufacturers Warranty
UEFI DualBIOS technology
At the heart of this exciting 3D BIOS technology is a pair of physical BIOS ROMs containing Gigabyte's exclusive in-house designed UEFI BIOS technology. With a superior graphical interface capable of 32-bit color imaging and fluid user-friendly mouse navigation, UEFI DualBIOS makes BIOS configuration an exciting experience for novice and experienced users alike. UEFI BIOS also brings native support for large hard drives on 64-bit operating systems. -
3D mode
Designed to provide an extremely streamlined and user-friendly BIOS environment, Gigabyte's exclusive 3D mode offers a fully interactive and illustrative GUI that allows users to easily and intuitively make key adjustments to the UEFI BIOS settings for optimum performance. 3D mode allows novice or casual users to more clearly understand the areas of the motherboard that are being affected through the BIOS settings, gaining a clearer understanding of the BIOS functionality. -
Advanced mode
Advanced mode provides a more comprehensive UEFI BIOS environment that is designed specifically for overclockers and power users who want maximum control over their PC's hardware. Gigabyte's signature M. I. T. tuning technology can be found alongside fully configurable parameters for Gigabyte's digital 3D Power engine. In short, advanced mode combines the signature Gigabyte BIOS expertise you've come to expect, wrapped a slick and optimized graphical UEFI interface. -
Intel Rapid Start Technology gets your device up and running faster from even the deepest sleep. This means users will be able to experience almost zero power draw from their PC, but be able to resume Windows 7 is a few seconds without having the PC go through a full system boot. With Intel Rapid Start Technology the previous session resumes to the exact as it was, so that applications are still in the same state and no application data is lost. -
Intel Smart Connect technology
Intel Smart Connect technology means that your email, favorite apps, and social networks are continually and automatically updated even when the system is asleep. No more waiting for the latest world news or friends' updates to be delivered - just press the 'on' button and you're up-to-date and ready to go. -
Humidity protection
Humidity can play havoc on a motherboard's circuitry. Gigabyte's Glass Fabric PCB design helps protect against electrical shorts due to humidity by reducing the gaps in spacing between PCB filaments. -
Power failure protection
Permanent damage from power surge or failure during BIOS update, can be avoided with Gigabyte DaulBIOS, which automatically enables a secondary, back up BIOS. GIGABYTE also uses Anti-Surge ICs to protect the motherboard against power surges. -
Onboard mSATA support
Gigabyte 7 series motherboards feature an onboard mSATA slot allowing users to easily take advantage of advanced SSD-based technologies like Intel Smart Response and Intel Rapid Start. Mounting an affordable, low capacity mSATA SSD directly onto your motherboard can enhance your PC's performance with better overall desktop responsiveness, faster boot times and faster system resume from 'suspend to disk' and 'standby' modes. -
Gigabyte on/off charge
Gigabyte 7 series motherboards feature on/off charge, a unique Gigabyte technology which allows you not only to charge your iPhone, iPad or iPod Touch, but also allows you to quick charge it. As an added bonus, it can even be charged when your PC is turned off, so even if you forget to plug it into your charger after you've synced up your music, it will be fully charged when you need it. -
Faster media encoding performance
Saves your valuable time when create and edit video, synchronize it with other devices, and share it - at home and on the Internet. Intel quick sync video uses hardware on the processor, instead of software, to accelerate video encoding. -
Multi-display support with AMD CrossFireX
AMD CrossFireX delivers the ultimate graphics performance for gaming enthusiasts who demand the highest frame rates without compromising on resolution.
- Gigabyte GA-Z77-DS3H - 1.0 - motherboard - ATX - LGA1155 Socket - Z77
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z77 Express
- Processor Socket
- 1 x LGA1155 Socket
- Compatible Processors
- Celeron, Core i5, Core i3, Core i7, Pentium G600 series, Pentium G800 series
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC
- Storage Ports
- 2 x SATA-600 (RAID), 4 x SATA-300 (RAID)
- USB / FireWire Ports
- 2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z77 Express
- Processor Socket
- LGA1155 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz
- Speed
- PC3-12800, PC3-10600, PC3-8500
- Supported RAM Integrity Check
- Non-ECC
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
- Audio Codec
- Realtek ALC887
- High Definition Audio
LAN
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin (1.5 V) , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 (x4 mode) , 2 x PCIe 2.0 x1 , 2 x PCI
- Storage Interfaces
- SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 3 x 7pin SATA, 1 x mSATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
- RAID Features
- Intel Smart Response Technology
- 1 x PS/2 keyboard / mouse , 1 x VGA , 1 x DVI-D , 1 x HDMI , 2 x USB 2.0 , 4 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
- Internal Interfaces
- 1 x audio , 1 x SPDIF out , 2 x USB 3.0 , 4 x USB 2.0 , 1 x serial
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Type
- AMI
- BIOS Features
- DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS, GIGABYTE 3D BIOS
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
- Hardware Features
- DualBIOS, Q-Flash, GIGABYTE eXtreme Hard Drive (XHD), AutoGreen, Intel Extreme Memory Profile (XMP) support, On/Off Charge, GIGABYTE 333 Onboard Acceleration, Ultra Durable 4 Classic, AMD CrossFireX technology support, Intel Rapid Start Technology, Intel Smart Connect Technology, GIGABYTE LAN Optimizer, Onboard mSATA Connector
- Software Included
- Norton Internet Security, @BIOS, Xpress Recovery 2, Q-Share, GIGABYTE EZ Smart Response, GIGABYTE 3D Power
- Plug and Play, ACPI 2.0a
- 30.5 cm
- 21.5 cm
