GIGABYTE 7 series motherboards combine a host of new and exciting technologies with the latest Intel Z77 Express Chipset, creating a unique range of motherboard designs that harness the outstanding performance of the new 3rd generation Intel® Core™ processors. With an exclusive 'All Digital' VRM design, GIGABYTE 3D Power and GIGABYTE 3D BIOS (Dual UEFI), GIGABYTE 7 series motherboards ensure exceptional power delivery and absolute control, with additional features that ensure an unrivalled experience on your next PC build.
- Support for the new INTEL 3rd Generation CPU's. On the socket 1155 platform.
- USB 3x Power Boost. Delivering greater device compatibility and faster charge times.
- Ultra Durable 4 Classic. Advanced temprature, humidity, electrostatic and power failure protection... The ultimate in reliability.
- Super Speed USB 3.0. Super fast transfer rates of up to 5 Gbps, 10x faster than USB 2.0.
- Lucid Virtu MVP. Producing faster frame rates, with sharper visuals and reduced tearing.
- Super SATA3 Native Suport. Supporting super fast 6Gbps link speeds.
- AMD Crossfirex. For multi display or ultimate performace gaming.
- PCIe GEN 3. Designed to take full advantage of the next generation high bandwidth graphic card solutions.
- UEFI DualBIOS™. A superior graphical BIOS interface, based on the trusted and secure GIGABYTE Dual BIOS technology.
- ON/OFF Charge Technology. Allows you to charge your iPad, iPhone or iPod even of your PC is off.
- Onboard mSATA Connector. Mount a low capcity mSATA SSD onto your motherboard to take advantage of INTEL SRT and RAPID START.
Tech Spec / Z77-D3H
- CPU: Support for Intel Core i7, i5, i3, Pentium and Celeron 1155 processors(Go to GIGABYTE's website for the latest CPU support list.)
- Chipset: Intel Z77 Express Chipset
- Memory: 4x DDR3 1600/1333/1066 MHz memory modules * Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
- Onboard Graphics: 1x D-Sub, 1x DVI-D (1920x1200 max res), 1x HDMI (1920x1200 max res)
- Audio: VIA VT2021 codec High Definition Audio 2/4/5.1/7.1-channel w/ Support for S/PDIF Out
- Multi-Graphics: Support for AMD CrossfireX
- LAN: 1 x Atheros GbE chip (10/100/1000 Mbit)
- Expansion Slots: 1 x PCI Express x16 slots, running at x16 / 1 x PCI Express x16 slots, running at x4 / 3x PCI Express x1 slot / 2x PCI slots
- Storage Interface: 2 x SATA 6Gb/s connectors / 4 x SATA 3Gb/s connectors / 1 x mSATA 3Gb/s (Disables sata connector 5 when in use)
- USB: USB 3.0/2.0 : 4x on the back panel, 2x via USB brackets on headers / USB 2.0/1.1 : 4x on the back panel, 6x via USB brackets on headers
- Internal I/O Connectors: 1 x 24-pin ATX main power connector, 1 x 4-pin ATX 12V power connector, 2 x SATA 6Gb/s connector, 4 x SATA 3GB/s connectors, 1 x mSATA connector, 1 x CPU fan header, 3 x system fan headers, 1 x front panel header, 1 x front panel audio header, 1 x S/PDIF Out header, 3 x USB 2.0/1.1 headers, 1 x USB 3.0/2.0 headers,1 x clearing CMOS jumper, 1 x TPM header, 1 x Serial port header
- Back Panel Connectors: 1 x PS/2 keyboard/mouse port, 1 x D-Sub, 1 x DVI-D, 1 x HDMI, 1 x Optical S/PDIF Out connector, 4 x USB 3.0/2.0 ports, 4 x USB 2.0/1.1 ports,1 x RJ-45 ports, 5x audio jacks
- BIOS: 2 x 64 Mbit AMI EFI BIOS, Support for DualBIOS™
- Form Factor: ATX Form Factor; 30.5 x 24.4cm
- Warranty: 3 Year Gigabyte Warranty
Gigabyte 3D power: digital voltage, frequency and phase control
Utilizing an digital controller array, Gigabyte's 3D power features precise auto voltage compensation to deliver a steady flow of power to the system, no matter the loading. With digital controllers for the CPU (Vcore), users can make real-time adjustments with the exclusive Gigabyte 3D power utility, that include settings such as OVP (Over Voltage Protection), Load-line Calibration and on-the-fly PWM frequency adjustment. -
3rd generation Intel Core processors
3rd generation Intel Core processors are based on the 3rd generation Intel Core processor architecture, manufactured using the latest 22 nm process to create a visually optimized processor platform. Based on the mature LGA 1155 socket, 3rd generation Intel Core processors feature up to four high-performance 64-bit processor cores and 8 MB of L3 cache smart cache, and overall performance when you need it most. -
Designed for PCI Express Gen. 3 support
Gigabyte 7 series motherboards take advantage of the latest connectivity and expansion bus technologies available on the Intel platform. The 3rd generation Intel Core processor platform debuts the PCI Express gen. 3.0 expansion bus, allowing users to take advantage of the next generation, high-bandwidth discrete graphics card solutions. -
Intel Smart Connect technology
Intel Smart Connect technology means that your email, favorite apps, and social networks are continually and automatically updated even when the system is asleep. No more waiting for the latest world news or friends' updates to be delivered - just press the 'on' button and you're up-to-date and ready to go. -
Humidity protection
Humidity can play havoc on a motherboard's circuitry. Gigabyte's glass fabric PCB design helps protect against electrical shorts due to humidity by reducing the gaps in spacing between PCB filaments. -
Electrostatic protection
Gigabyte Ultra Durable 4 classic motherboards feature high resistance ICs which help protect the motherboard against electrostatic discharge. -
Power failure protection
Permanent damage from power surge or failure during BIOS update, can be avoided with Gigabyte DaulBIOS, which automatically enables a secondary, back up BIOS. Gigabyte also uses Anti-Surge ICs to protect the motherboard against power surges. -
High temperature protection
Gigabyte uses all solid caps (Capacitors) and low RDS(on) MOSFETs which are rated to work at higher temperatures, providing up to 50,000 hour component lifespan. -
Lucid universal MVP support
Gigabyte 7 series motherboards support Lucid Virtu GPU virtualization technologies - optimized virtualization software that improves your PC's visuals, with faster response times, improved video processing and smoother media playback, all within a low power environment. Lucid Universal MVP also features Hyperformance, which eliminates redundant rendering tasks and predicts potential synchronization issues in the graphics delivery pipeline, producing faster frame rates, sharper visuals and reduced tearing. -
Gigabyte EZ smart response
The Gigabyte EZ smart response utility is a simple application that allows users to quickly and easily configure their system for Intel smart response technology. In the past, enabling Intel smart response meant users needed to enter the BIOS in order to configure their system for RAID mode, which then required a complete reinstall of the operating system. Once that processes was complete, users then needed to install the Intel Rapid Storage Utility as well as configure Intel's smart response technology. Gigabyte EZ smart response does all of this automatically, without users having to perform a complicated install process. This allows them to quickly and effortlessly enjoy a significant boost in system performance. -
Gigabyte EZ setup
Gigabyte EZ setup is an exclusive application that allows Gigabyte 7 series users to more easily configure and setup three important Intel Technologies on their system; Intel smart response, Intel rapid start and Intel smart connect. Gigabyte EZ setup makes it far easier to enjoy these technologies by greatly reducing the number of steps involved to install setup and configure your system. -
Onboard mSATA support
Gigabyte 7 series motherboards feature an onboard mSATA slot allowing users to easily take advantage of advanced SSD-based technologies like Intel smart response and Intel rapid start. Mounting an affordable, low capacity mSATA SSD directly onto your motherboard can enhance your PC's performance with better overall desktop responsiveness, faster boot times and faster system resume from 'suspend to disk' and 'standby' modes. -
Gigabyte 333 onboard acceleration
Gigabyte 7 series motherboards feature Gigabyte 333 onboard acceleration, that are designed help speed up data transfer, including SuperSpeed USB 3.0 technology, SATA revision 3.0 (6 Gbps) technology and an unprecedented 3x USB power boost on all USB ports for more power hungry USB devices. -
Gigabyte on/off charge
GIGABYTE 7 series motherboards feature on/off charge, a unique Gigabyte technology which allows you not only to charge your iPhone, iPad or iPod Touch, but also allows you to quick charge it. As an added bonus, it can even be charged when your PC is turned off, so even if you forget to plug it into your charger after you've synced up your music, it will be fully charged when you need it. -
LAN optimizer - intelligent optimization network management tool
Gigabyte LAN optimizer is designed to allow the user to manage different types of network traffic so that data streams such as HD media, web browsing or online gaming can be prioritized, taking precedence over large data downloads that tend to strangle overall network bandwidth. -
Multi-display support with AMD CrossFireX
AMD CrossFireX delivers the ultimate graphics performance for gaming enthusiasts who demand the highest frame rates without compromising on resolution.
- Gigabyte GA-Z77-D3H - 1.0 - motherboard - ATX - LGA1155 Socket - Z77
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z77 Express
- Processor Socket
- 1 x LGA1155 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC
- Storage Ports
- 2 x SATA-600 (RAID), 4 x SATA-300 (RAID)
- USB / FireWire Ports
- 4 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z77 Express
- Processor Socket
- LGA1155 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz
- Speed
- PC3-12800, PC3-10600, PC3-8500
- Supported RAM Integrity Check
- Non-ECC
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
- Audio Codec
- VIA VT2021
- High Definition Audio
LAN
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin (1.5 V) , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 , 3 x PCIe 2.0 x1 , 2 x PCI
- Storage Interfaces
- SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin SATA, 1 x mSATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
- RAID Features
- Intel Smart Response Technology
- 1 x PS/2 keyboard / mouse , 4 x USB 2.0 , 4 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DVI-D , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in/microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK
- Internal Interfaces
- 2 x USB 3.0 , 6 x USB 2.0 , 1 x SPDIF out , 1 x audio
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Type
- AMI
- BIOS Features
- DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS, GIGABYTE 3D BIOS
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
- Hardware Features
- DualBIOS, Q-Flash, GIGABYTE eXtreme Hard Drive (XHD), AutoGreen, Intel Extreme Memory Profile (XMP) support, On/Off Charge, Intel Smart Response Technology, GIGABYTE 3D Power, GIGABYTE 333 Onboard Acceleration, Ultra Durable 4 Classic, AMD CrossFireX technology support, Intel Rapid Start Technology, Intel Smart Connect Technology, Lucid Virtu MVP, GIGABYTE LAN Optimizer, Onboard mSATA Connector
- Software Included
- Norton Internet Security, @BIOS, Xpress Recovery 2, Q-Share, GIGABYTE EZ Smart Response, GIGABYTE 3D Power
- Plug and Play, ACPI 2.0a
- 30.5 cm
- 24.4 cm
