Gigabyte X99-UD5 WIFI S2011 Intel X99 DDR4 EATX
Quicklinx: 9P9KWS00 Mfr#: GA-X99-UD5 WIFI
  • Bluetooth 4.0
  • IEEE 802.11n
Genuine All Digital Power Design
GIGABYTE X99 series motherboards use an all digital CPU power design from International Rectifier® which includes both 4th Generation digital PWM Controllers and industry-leading 3rd Generation PowIRstage® controllers. These 100% digital controllers offer incredible precision in delivering power to the motherboard's most power-hungry and energy-sensitive components, allowing enthusiasts to get the absolute maximum performance from their new Intel® Core™ i7 Extreme Edition CPUs.
IR Digital PWM & IR PowIRstage® ICs
This new generation of IR® digital power controllers and PowIRstage® ICs feature Isense technology, which provide more precise current sensing accuracy. This helps evenly distribute the thermal loading between the PowerIRstage® ICs, preventing the overheating of each individual PowerIRstage®, resulting in longer lifespan and better reliability.
Single Package Design
IR® has leveraged it's world class packaging technology developed for the DirectFET®, improving the thermal capability and layout of the PowIRstage® significantly over that of other MCM packages.
  • Supports New Intel® Core™ i7 Processor Extreme Edition
  • 4 Channel DDR4, 8 DIMMs
  • Genuine All Digital Power Design with IR Digital PWM & IR PowIRstage® ICs
  • 4-Way Graphics with Premium PCIe Lane
  • Dual M.2 Technology for SSD Drive and Onboard WIFI card
  • 6x(30µ) Gold Plating for CPU socket, Memory DIMMs and PCIe slots
  • Realtek ALC1150 115dB SNR HD audio with built-in Rear Audio Amplifier
  • Independent Right and Left Audio Channel PCB Layers
  • LED lighting for the audio guard light path and the back panel LED
  • All Stainless Steel connectors on rear panel
  • High end quality audio capacitors
  • Dual Intel GbE LAN with Teaming functionality
  • SATA Express support for up to 10 Gb/s data transfer
  • Long lifespan Durable Black™ Solid caps
  • APP Center including EasyTune™ and Cloud Station™ utilities
  • Thunderbolt™ Ready
  • GIGABYTE UEFI DualBIOS™ with Q-Flash Plus USB port
  • Safer design around screw mounting holes
  • Genuine all digital power design
    Gigabyte X99 series motherboards use an all digital CPU power design from International Rectifier which includes both 4th Generation digital PWM Controllers and industry-leading 3rd Generation PowIRstage controllers. These 100% digital controllers offer incredible precision in delivering power to the motherboard's most power-hungry and energy-sensitive components, allowing enthusiasts to get the absolute maximum performance from their CPUs.
  • IR Digital PWM & IR PowIRstage ICs
    IR digital power controllers and PowIRstage ICs feature Isense technology, which provide more precise current sensing accuracy. This helps evenly distribute the thermal loading between the PowerIRstage ICs, preventing the overheating of each individual PowerIRstage, resulting in longer lifespan and better reliability.
  • Single package design
    IR has leveraged it's world class packaging technology developed for the DirectFET, improving the thermal capability and layout of the PowIRstage significantly over that of other MCM packages.
  • 3-Way / 4-Way Graphics with Premium PCIe x16 Lane Up to 320Gb/s Bandwidth
    Gigabyte X99 motherboards feature a unique PCI Express design that utilizes 100% of all 40 lanes from the CPU when in a 4-Way or 3-Way graphics configuration. Standard designs limit all 4 main PCIe lanes to x8 (64Gb/s) bandwidth, but thanks to the onboard external clock generator combined with the direct connection of one of the x16 lanes to the CPU (switchless design), Gigabyte X99 motherboards can unlock the full bandwidth available and provide the best graphics bandwidth possible to the user.
  • Q-Flash plus
    Gigabyte Q-Flash Plus allows users to update to the latest BIOS using a thumb drive without the CPU or memory needing to be installed.Do you have the latest CPU supported by your GIGABYTE motherboard but do not have the latest BIOS installed yet? This is no longer a problem with the Q-Flash Plus feature. By simply downloading the latest BIOS and renaming it on a USB thumb drive, and plugging it into the dedicated port, you can now flash the BIOS automatically without the need to press any buttons or even the need of onboard memory or CPU. Utilizing the ITE EC 8951E controller, Gigabyte X99 motherboard BIOS can be updated even if your system is unable to boot. An LED next to the EC controller will notify you once the procedure is complete and you are ready to boot your system normally.
  • Ambient LED
    Gigabyte X99 motherboards feature LED lighting for the audio guard light path and the back panel LED, providing a cool, custom look to your rig. These lights are now programmable, so you can have them beat to the rhythm of the music you are listening to, or pulse at a soothing pace to create a great atmosphere to enhance the environment of your game, movie or music.
Gigabyte GA-X99-UD5 WIFI - 1.0 - motherboard - extended ATX - LGA2011-v3 Socket - X99
Motherboard - extended ATX
Chipset Type
Intel X99 Express
Processor Socket
1 x LGA2011-v3 Socket
Compatible Processors
Core i7 Extreme Edition, Core i7, Xeon E5-2600 v3 series, Xeon E5-1600 v3 series
Max RAM Size
64 GB
RAM Supported
8 DIMM slots - DDR4, non-ECC, registered, unbuffered
Storage Ports
6 x SATA-600 (RAID), 4 x SATA-600, 1 x SATA Express port, 1 x M.2
USB / FireWire Ports
8 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Bluetooth, 2 x Gigabit Ethernet, 802.11a/b/g/n/ac
Chipset Type
Intel X99 Express
Processor Socket
LGA2011-v3 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Registered, unbuffered
Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
Audio Codec
Realtek ALC1150
High Definition Audio
LAN
Network Interfaces
Expansion Slots
1 x CPU , 8 x DIMM 288-pin , 1 x PCIe 3.0 x16 (x16 mode (x8 mode if PCI Express 3.0 x8 slot is occupied)) , 1 x PCIe 3.0 x16 , 2 x PCIe 3.0 x16 (x8 mode) , 3 x PCIe 2.0 x1 , 1 x M.2 socket
Storage Interfaces
SATA-600 -connectors: 6 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices
RAID Features
Intel Smart Response Technology
2 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 8 x USB 3.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK , 1 x PS/2 keyboard / mouse
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x audio - header , 1 x Thunderbolt - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
V-Check Points, NVIDIA 3-way SLI Technology Support, Teaming Technology, Intel Extreme Memory Profile (XMP) support, NVIDIA 2-way SLI Technology Support, On/Off Charge, Intel Smart Response Technology, NVIDIA 4-way SLI Technology Support, AMD CrossFireX technology support, AMD 3-way CrossFireX technology support, Onboard Button, AMD 4-way CrossFireX technology support, All IR digital power design, CFOS Speed Internet Accelerator Software support, 2x Copper PCB, Clear CMOS Button, Debug LED, GIGABYTE Smart Switch, Q-Flash Plus, IR PowIRstage ICs, DirectFET, GIGABYTE Ambient LED, Cooper Bussmann Chokes, Durable Black Solid Caps, Rear Panel LED, Stainless Steel rear connectors
Software Included
Norton Internet Security, @BIOS, EasyTune, Cloud Station, GIGABYTE EZ Setup, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed, Smart TimeLock, GIGABYTE Fast Boot, GIGABYTE V-Tuner
Plug and Play, ACPI 5.0
30.5 cm
25.9 cm
