Gigabyte motherboards are equipped with the very best quality components that ensure that you PC is running at maximum power efficiency. Lower RDS(on) MOSFETs reduce energy wastage through unnecessary residual heat dissipation. This all amounts to tangible energy savings which are beneficial for both end-users and the environment without impacting system performance. Gigabyte Ultra Durable motherboards are equipped with all solid capacitors. With an average lifespan of 50,000 hours, these solid capacitors provide the stability, reliability and longevity essential to meet the power needs of high-end processors and other components running today's most demanding applications and games.
- Super Safe
- DualBIOS 3TB+ HDD Support (Hybrid EFI Technology)
- 50,000 Hours All Solid Capacitors
- Super Savings
- Gigabyte Touch BIOS
- New 100% Hardware VRD 12 Compliant CPU Power Design
- Intel HD Graphics Core 2000/3000 Enhanced Visual Features
- Smart 6 - Smarter PC system Management
- AutoGreen- Greening your PC via Bluetooth cellphone
- ErP Lot 6 support
- 3 Years Manufacturers Warranty
- CPU: Support for Intel Core i7 processors/Intel Core i5 processors/ Intel Core i3 processors/Intel Pentium processors/Intel Celeron processors in the LGA1155 package, L3 cache varies with CPU
- Chipset: Intel H61 Express Chipset
- Memory: 2 x 1.5V DDR3 DIMM sockets supporting up to 16 GB of system memory, Dual channel memory architecture, Support for DDR3 1333/1066/800 MHz memory modules, Support for non-ECC memory modules
- Onboard Graphics Integrated in the Chipset: 1 x D-Sub port
- Audio: VIA VT1708 codec, High Definition Audio, 2/4/5.1/7.1-channel
- LAN: 1 x Atheros AR8151 chip (10/100/1000 Mbit)
- Expansion Slots: 1 x PCI Express x16 slot, running at x16, 3 x PCI Express x1 slots
- Storage Interface Chipset: 4 x SATA 3Gb/s connectors supporting up to 4 SATA 3Gb/s devices
- USB Chipset: Up to 8 USB 2.0/1.1 ports (4 ports on the back panel, 4 ports available through the internal USB headers)
- nternal I/O Connectors: 1 x 24-pin ATX main power connector, 1 x 4-pin ATX 12V power connector, 4 x SATA 3Gb/s connectors, 1 x CPU fan header, 1 x system fan header, 1 x front panel header, 1 x front panel audio, header, 2 x USB 2.0/1.1 headers, 1 x parallel port header, 1 x serial port header, 1 x power LED header, 1 x chassis intrusion header, 1 x clearing CMOS jumper
- Back Panel Connectors: 1 x PS/2 keyboard port, 1 x PS/2 mouse port, 1 x D-Sub port, 4 x USB 2.0/1.1 ports, 1 x RJ-45 port, 3 x audio jacks (Line In/Line Out/Microphone)
- I/O Controller: iTE IT8728 chip
- H/W Monitoring: System voltage detection, CPU/System temperature detection, CPU/System fan speed detection, CPU/System fan speed control
- BIOS: 2 x 32 Mbit flash, Use of licensed AWARD BIOS, Support for DualBIOS, PnP 1.0a, DMI 2.0, SM BIOS 2.4, ACPI 1.0b
- Warranty: 3 Years Manufacturers Warranty
DualBIOS 3TB+ HDD support (Hybrid EFI technology)
Hybrid EFI Technology combines the benefits of GIGABYTE's mature BIOS platform including stability and compatibility with 3rd party products with 3TB+ HDD support from EFI technology, allowing GIGABYTE to offer the best of both worlds through a quick and easy BIOS update using GIGABYTE's @BIOS utility that is freely available from the GIGABYTE website. GIGABYTE DualBIOS is a patented technology that automatically recovers BIOS data when the main BIOS has crashed or failed. Featuring 2 physical BIOS ROMs integrated onboard, GIGABYTE DualBIOS allows quick and seamless recovery from BIOS damage or failure due to viruses or improper BIOS updating. In addition, GIGABYTE DualBIOS now supports 3TB+ (terabyte) hard drive booting without the need for partitioning, and enables more data storage on a single hard drive. 50,000 Hours All Solid Capacitors GIGABYTE Ultra Durable motherboards are equipped with all solid capacitors. With an average lifespan of 50,000 hours, these solid capacitors provide the stability, reliability and longevity essential to meet the power needs of high-end processors and other components running today's most demanding applications and games. -
An innovative new way to modify BIOS settings
Navigating through the BIOS to change system settings can be a daunting task for users not familiar with control "F"functions and mouse-less navigation. While some EFI BIOS try to address this with a mouse friendly environment, many implementations still lack a certain ease-of-use necessary for most people. With GIGABYTE Touch BIOS, GIGABYTE engineers have completely re-imagined how users can interact with their BIOS, allowing for a more intuitive user experience. In fact, with a touch screen monitor, GIGABYTE Touch BIOS is as easy to use as most apps on your iPhone. -
New 100% hardware VRD 12 compliant CPU power design
GIGABYTE 6 series motherboards incorporate an Intel approved Intersil PWM controller that is VRD 12 (Voltage Regulator Down) compliant. This means that it offers new features that include SerialVID (SVID) which transfers power management information between the processor and voltage regulator controller, allowing more robust and efficient signaling control between the CPU and PWM controller - hence, delivering a more energy efficient platform. Intel HD Graphics Core 2000/3000 Enhanced Visual Features -
Intel Quick Sync Video
Intel Quick Sync Video provides breakthrough media processing for incredibly fast editing and sharing. -
Intel InTru 3D
2nd Generation Intel Core Processors offer an outstanding Blu-Ray Stereo 3D experience in full high definition resolution (1080p) with HDMI 1.4. -
Intel Advanced Vector Extensions (AVX)
Increases the performance of Accelerated Floating Point and Vector Computing Intensive Applications with minimal power gains.
- Gigabyte GA-H61M-S2-B3 - 1.0 - motherboard - micro ATX - LGA1155 Socket - H61
- Product Type
- Motherboard - micro ATX
- Chipset Type
- Intel H61 Express / ITE IT8728
- Processor Socket
- 1 x LGA1155 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- RAM Installed
- 0 GB
- Max RAM Size
- 16 GB
- RAM Supported
- 2 DIMM slots - DDR3, non-ECC
- Storage Ports
- 4 x SATA-300
- USB / FireWire Ports
- 4 x USB 2.0 + (4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- Product Type
- Chipset Type
- Processor Socket
- LGA1155 Socket
- Max Processors Qty
- 1
- RAM Installed
- 0 GB
Supported RAM
- Max Size
- 16 GB
- Technology
- DDR3
- Bus Clock
- 1333 MHz, 1066 MHz, 800 MHz
- Speed
- PC3-10600, PC3-8500, PC3-6400
- Supported RAM Integrity Check
- Non-ECC
- Dual channel memory architecture
Audio
- Audio Codec
- VIA VT1708
- High Definition Audio
LAN
- Network Controller
- Atheros AR8151
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 2 x DIMM 240-pin (1.5 V) , 1 x PCIe 2.0 x16 , 3 x PCIe 2.0 x1
- Storage Interfaces
- SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices
- 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
- Internal Interfaces
- 4 x USB 2.0 , 1 x parallel , 1 x serial
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Type
- Award
- BIOS Features
- DMI 2.0 support, ACPI 1.0b support, SMBIOS 2.4 support, Hybrid EFI Technology, Touch BIOS, Xpress BIOS Rescue
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage
- Hardware Features
- Chassis intrusion detection, DualBIOS, Smart 6, AutoGreen, All-Solid Capacitor motherboard Design, On/Off Charge, Voltage Regulator Down 12 (VRD) compliant, Ultra Durable
- Software Included
- Drivers & Utilities, Norton Internet Security, @BIOS, Xpress Recovery 2, Q-Share, Cloud OC, EasyTune
- Plug and Play, ACPI 1.0b, Energy-Related Products (ErP) Lot 6
- 24.4 cm
- 19.5 cm
Gigabyte S1155 Intel H61 DDR3 mATX
