The GIGABYTE Radeon RX 7700 XT GAMING OC 12G is designed to deliver exceptional gaming and creative performance. With 12 GB of GDDR6 SDRAM and a boost clock speed of 2599 MHz, it offers the speed and power to handle demanding games and applications with ease. The card supports DirectX 12 Ultimate and OpenGL 4.6, enabling advanced visual effects and gaming features for an immersive experience.
Its cooling system, featuring the GIGABYTE WINDFORCE design with triple 90 mm fans, graphene nano lubricant, and a copper base, ensures optimal performance by keeping temperatures low during intense gaming sessions. Additionally, the card's support for up to 4 monitors and high-resolution outputs up to 7680 x 4320 allows for a versatile setup, whether for gaming, content creation, or productivity tasks. With its robust build and performance-enhancing features, the GIGABYTE Radeon RX 7700 XT GAMING OC 12G is an excellent choice for gamers and creative professionals looking for a high-quality video card.
Enhanced cooling
The GIGABYTE Radeon RX 7700 XT GAMING OC 12G features the GIGABYTE WINDFORCE cooling design, incorporating triple 90 mm fans, graphene nano lubricant, and a copper base to ensure your video card remains cool under pressure, enhancing performance and durability. -
Superior visuals
With a boost clock speed of 2599 MHz and 12 GB of GDDR6 SDRAM, this graphics card delivers stunning visuals and smooth gameplay. The support for DirectX 12 Ultimate and OpenGL 4.6 enables advanced gaming effects for an immersive gaming experience. -
Advanced connectivity
Equipped with 2 HDMI and 2 DisplayPort outputs, supporting up to 4 monitors and a maximum external resolution of 7680 x 4320, this video card offers versatile connectivity options for a multi-display setup or high-resolution gaming and content creation.
- Gigabyte Radeon RX 7700 XT GAMING OC 12G - OC Edition - graphics card - Radeon RX 7700 XT - 12 GB
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- AMD Radeon RX 7700 XT
- Memory
- 12 GB GDDR6
- Memory Speed
- 18 Gbps
- Boost Clock
- 2599 MHz
- Stream Processors
- 3456
- Memory Interface
- 192-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- 2 x HDMI , 2 x DisplayPort
- API Supported
- DirectX 12 Ultimate, OpenGL 4.6
- 5.6 cm x 30.2 cm x 13 cm
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- Boost Clock
- 2599 MHz
- Stream Processors
- 3456
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- Triple Fan Design, RGB fusion, Dual Bios, GIGABYTE WINDFORCE cooling design, metal backplate, RDNA 3 Gaming Architecture, Triple 90mm Fan Design, copper base, Gigabyte Alternate Spinning, Graphene Nano Lubricant, Ultra Durable VGA, AMD Radeon Anti Lag Technology, AMD Noise Suppression, Radeon Image Sharpening, AMD Radeon Boost Technology, AMD FidelityFX Super Resolution (FSR), AMD Link
- Size
- 12 GB
- Technology
- GDDR6 SDRAM
- Memory Speed
- 18 Gbps
- Bus Width
- 192-bit
- Required Power Supply
- 700 W
- Additional Requirements
- 2 x 8 pin PCI Express power connector
- Software Included
- Gigabyte Control Center
- DisplayPort 2.1
- 5.6 cm
- 30.2 cm
- 13 cm
