WINDFORCE 3X Cooling System
The WINDFORCE 3X cooling system features 3x 80mm unique blade fans, alternate spinning, 3 composite copper heat pipes direct touch GPU, 3D active fan and Screen cooling, which together provide high efficiency heat dissipation.
Smooth Airflow
GIGABYTE turns the adjacent fans in the opposite direction, so that the airflow direction between the two fans is the same, reducing the turbulence and enhancing the airflow pressure.
3D Active Fan
The 3D Active Fan provides semi-passive cooling, and the fans will remain off when the GPU is in a low load or low power game.
Unique Blade Fan
The airflow is spilt by the triangular fan edge, and guided smoothly through the 3D stripe curve on the fan surface.
Graphene Nano Lubricant Graphene nano lubricant can extend the life of fan by 2.1 times, close to the life of double ball bearing, and is quieter.
Screen Cooling
Extended heatsink design allows air flow to pass through, providing better heat dissipation.
Heat Pipes Direct Touch
The shape of the pure copper heat pipe maximises the direct contact area with the GPU. The heat pipe also covers the VRAM through a large metal plate contact to ensure proper cooling.
Protection Back Plate
The back plate not only provides an aesthetical shape, but also enhances the structure of the graphics card to provide complete protection.
Extreme Durability
The graphics card uses the better power phase design to allow the MOSFET to operate at lower temperature, and over-temperature protection design and load balancing for each MOSFET, plus the Ultra Durable certified chokes and capacitors, to provide excellent performance and longer system life.
Friendly PCB Design
Fully automated production process ensures top quality of the circuit boards and eliminates sharp protrusions of the solder connectors seen on the conventional PCB surface. This friendly design prevents your hands from getting cut or inadvertently damaging components when making your build.
AORUS Engine
The cutting edge intuitive interface allows you to adjust the clock speed, voltage, fan performance and power target in real-time according to your game’s requirements.
AMD FreeSync
No stuttering. No tearing. Just gaming. AMD FreeSync™ technology puts an end to choppy gameplay and broken frames with fluid, artefact-free performance at virtually any framerate
- Powered by AMD RDNA™ 2 Radeon™ RX 6600.
- Integrated with 8GB GDDR6 128-bit memory interface.
- WINDFORCE 3X Cooling System with alternate spinning fans.
- Screen cooling.
- Graphene nano lubricant.
- Protection back plate.
- Up to 2491 MHz Boost Clock.
- Up to 2044 MHz Game Clock.
The WINDFORCE 3X cooling system features 3x 80mm unique blade fans, alternate spinning, 3 composite copper heat pipes direct touch GPU, 3D active fan and Screen cooling, which together provide high efficiency heat dissipation. -
Alternate spinning
Reduce the turbulence of adjacent fans and increase air pressure. -
Smooth airflow
GIGABYTE turns the adjacent fans in the opposite direction, so that the airflow direction between the two fans is the same, reducing the turbulence and enhancing the airflow pressure. -
3D active fan
The 3D Active Fan provides semi-passive cooling, and the fans will remain off when the GPU is in a low load or low power game. -
Unique blade fan
The airflow is spilt by the triangular fan edge, and guided smoothly through the 3D stripe curve on the fan surface. -
Graphene nano lubricant can extend the life of fan by 2.1 times, close to the life of double ball bearing, and is quieter. -
Screen cooling
Extended heatsink design allows air flow to pass through, providing better heat dissipation. -
Heat pipes direct touch
The shape of the pure copper heat pipe maximizes the direct contact area with the GPU. The heat pipe also covers the VRAM through a large metal plate contact to ensure proper cooling. -
The back plate not only provides an aesthetical shape, but also enhances the structure of the graphics card to provide complete protection. -
Extreme durability
The graphics card uses the better power phase design to allow the MOSFET to operate at lower temperature, and over-temperature protection design and load balancing for each MOSFET, plus the Ultra Durable certified chokes and capacitors, to provide excellent performance and longer system life. -
Friendly PCB design
- Gigabyte Radeon RX 6600 EAGLE 8G - graphics card - Radeon RX 6600 - 8 GB
- Graphics card
- Bus Type
- PCI Express 4.0 x16
- Graphics Engine
- AMD Radeon RX 6600 - up to
- Memory
- 8 GB GDDR6
- Boost Clock
- 2491 MHz
- Stream Processors
- 1792
- Effective Memory Clock
- 14000 MHz
- Memory Interface
- 128-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- 2 x DisplayPort , 2 x HDMI
- API Supported
- DirectX 12 Ultimate, OpenGL 4.6
- 4.1 cm x 28.2 cm x 11.3 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Boost Clock
- 2491 MHz
- Stream Processors
- 1792
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- RDNA 2 Architecture, GIGABYTE WindForce 3x, Gigabyte Alternate Spinning, 80mm Unique blade fan design, Heat Pipe Direct Touch technology, 3D Active Fan, FreeSync Technology, AMD Radeon Anti Lag Technology, AMD Radeon Boost Technology, Radeon Image Sharpening, Radeon Chill, AMD FidelityFx
- Size
- 8 GB
- Technology
- GDDR6 SDRAM
- Effective Clock Speed
- 14000 MHz
- Bus Width
- 128-bit
- Bandwidth
- 224 GBps
- Required Power Supply
- 500 W
- Additional Requirements
- 8 pin PCI Express power connector
- Software Included
- AORUS Engine
- DisplayPort 1.4a
- 4.1 cm
- 28.2 cm
- 11.3 cm
- Limited warranty - 3 years
