Gigabyte Radeon RX 580 GAMING 8GB GDDR5 PCIe Graphics Card
Quicklinx: CVCHWS00 Mfr#: GV-RX580GAMING-8GD
The WindForce 2x cooling system features 3 pure copper composite heat-pipes, heat-pipe direct touch GPU, unique blade fan design, 3D active fan with LED indicators, stylish metal back plate, together delivering an effective heat dissipation capacity for higher performance at lower temperatures. The metal back plate offers rigidity and protection to the structure, while adding a sleek, clean look to the product. Engineered with the high-grade chokes and capacitors, this graphic card delivers outstanding performance and durable system lifespan.
  • WindForce 2x cooling system
  • Stylish metal back plate
  • Ultra-durable materials
Gigabyte Radeon RX 580 Gaming 8G - graphics card - Radeon RX 580 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon RX 580 - up to
8 GB GDDR5
Core Clock
1355 MHz
Effective Memory Clock
8 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
5
Interfaces Details
HDMI , 3 x DisplayPort , DVI-D (dual link)
API Supported
DirectX 12, OpenGL 4.5
4 cm x 23.2 cm x 11.6 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon RX 580
Core Clock
1355 MHz
Process Technology
14 nm
VR Ready
Max Resolution
7680 x 4320
5
Interfaces Details
API Supported
Ultra Durable VGA, LED indicator, AMD Eyefinity Technology, GIGABYTE WindForce 2x, AMD CrossFireX Technology, FreeSync Technology, AMD VR Ready Premium, AMD XConnect Technology, 90mm Unique blade fan design, AORUS Graphics Engine
Size
8 GB
GDDR5 SDRAM
Effective Clock Speed
8 GHz
Bus Width
256-bit
Required Power Supply
500 W
Additional Requirements
8 pin PCI Express power connector
4 cm
23.2 cm
11.6 cm
