Gigabyte Radeon RX 580 AORUS XTR 8GB GDDR5 PCIe Graphics Card
Quicklinx: CVCFWS00 Mfr#: GV-RX580XTRAORUS-8GD
The AORUS graphics cards are crafted for perfection in pursuit of a great graphics experience for gaming enthusiasts. The AORUS graphics card brings you incredible gaming experience.
  • All-around cooling solution
    AORUS provides the all-around cooling solution for all key components of the graphics card. On the front side, the GPU is in direct touch with the heat pipes to dissipate heat from the GPU. On the back side, the copper back plate dissipates the heat from the GPU back side.
  • Heat pipes direct touch
    The pure copper heat pipes are shaped to maximize the direct contact area to the GPU for enhanced thermal transfer.
  • Advanced copper back plate cooling
    Excessive heat from GPU not only gets dissipated utilizing the massive cooling module in the front but also through the back side with a copper plate, providing a well-rounded thermal solution for the GPU.
  • Unique blade fan
    The airflow is split by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the airflow.
Gigabyte AORUS Radeon RX580 XTR 8G - graphics card - Radeon RX 580 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon RX 580 - up to
8 GB GDDR5
Core Clock
1439 MHz
Effective Memory Clock
8 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
5
Interfaces Details
HDMI , 3 x DisplayPort , DVI-D (dual link)
API Supported
DirectX 12, OpenGL 4.5
5.464 cm x 27.55 cm x 13.328 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon RX 580
Core Clock
1439 MHz
Process Technology
14 nm
VR Ready
Max Resolution
7680 x 4320
5
Interfaces Details
API Supported
AMD Eyefinity Technology, GIGABYTE WindForce 2x, AMD CrossFireX Technology, FreeSync Technology, AMD VR Ready Premium, AMD XConnect Technology, AORUS Graphics Engine, 100mm Blade Fan Design
Size
8 GB
GDDR5 SDRAM
Effective Clock Speed
8 GHz
Bus Width
256-bit
Required Power Supply
500 W
Additional Requirements
8 pin PCI Express power connector
5.464 cm
27.55 cm
13.328 cm
