Gigabyte Radeon RX 580 AORUS 8GB GDDR5 PCIe Graphics Card
Quicklinx: CVCGWS00 Mfr#: GV-RX580AORUS-8GD
AORUS graphics cards are crafted for perfection in pursuit of the ultimate graphics experience for gaming enthusiasts. Based on the revolutionary architecture, AORUS graphics card brings you incredible gaming experience.
  • AORUS all-around cooling solution
    AORUS provides the all-around cooling solution for all key components of the graphics card. On the front side, the GPU direct touch heat-pipes combine a metal base plate to dissipate heat from the GPU and VRAM. On the back side, the copper back plate dissipates the heat from the GPU back side. All other key components are taken care of very well by the WINDFORCE cooling module. AORUS ensures the customer a better cooling solution in many ways.
  • Stylish metal back plate
    The metal back plate offers rigidity and protection to the structure, while adding a sleek, clean look to the product.
Gigabyte AORUS Radeon RX580 8G - graphics card - Radeon RX 580 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon RX 580 - up to
8 GB GDDR5
Core Clock
1380 MHz
Effective Memory Clock
8 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
5
Interfaces Details
HDMI , 3 x DisplayPort , DVI-D (dual link)
API Supported
DirectX 12, OpenGL 4.5
3.6 cm x 23.2 cm x 12.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon RX 580
Core Clock
1380 MHz
Process Technology
14 nm
VR Ready
Max Resolution
7680 x 4320
5
Interfaces Details
API Supported
AMD Eyefinity Technology, GIGABYTE WindForce 2x, AMD CrossFireX Technology, FreeSync Technology, AMD VR Ready Premium, AMD XConnect Technology, 90mm Unique blade fan design, AORUS Graphics Engine
Size
8 GB
GDDR5 SDRAM
Effective Clock Speed
8 GHz
Bus Width
256-bit
Required Power Supply
500 W
Additional Requirements
8 pin PCI Express power connector
AORUS metal sticker
3.6 cm
23.2 cm
12.1 cm
