AORUS graphics cards are crafted for perfection in pursuit of the ultimate graphics experience for gaming enthusiasts. Based on the revolutionary architecture, AORUS graphics card brings you incredible gaming experience.
AORUS all-around cooling solution
AORUS provides the all-around cooling solution for all key components of the graphics card. On the front side, the GPU direct touch heat-pipes combine a metal base plate to dissipate heat from the GPU and VRAM. On the back side, the copper back plate dissipates the heat from the GPU back side. All other key components are taken care of very well by the WINDFORCE cooling module. AORUS ensures the customer a better cooling solution in many ways. -
Stylish metal back plate
The metal back plate offers rigidity and protection to the structure, while adding a sleek, clean look to the product.
- Gigabyte AORUS Radeon RX580 4G - graphics card - Radeon RX 580 - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon RX 580 - up to
- Memory
- 4 GB GDDR5
- Core Clock
- 1380 MHz
- Effective Memory Clock
- 7000 MHz
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 5
- Interfaces Details
- HDMI , 3 x DisplayPort , DVI-D (dual link)
- API Supported
- DirectX 12, OpenGL 4.5
- 3.6 cm x 23.2 cm x 12.1 cm
- Graphics card
- Bus Type
- Graphics Engine
- AMD Radeon RX 580
- Core Clock
- 1380 MHz
- Process Technology
- 14 nm
- VR Ready
- Max Resolution
- 7680 x 4320
- 5
- API Supported
- AMD Eyefinity Technology, GIGABYTE WindForce 2x, AMD CrossFireX Technology, FreeSync Technology, AMD VR Ready Premium, AMD XConnect Technology, 90mm Unique blade fan design, AORUS Graphics Engine
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7000 MHz
- Bus Width
- 256-bit
- Required Power Supply
- 500 W
- Additional Requirements
- 8 pin PCI Express power connector
- Included Accessories
- AORUS metal sticker
- 3.6 cm
- 23.2 cm
- 12.1 cm
