Gigabyte Radeon RX 570 AORUS 4GB GDDR5 PCIe Graphics Card
Quicklinx: CVCMWS00 Mfr#: GV-RX570AORUS-4GD
AORUS provides the all-around cooling solution for all key components of the graphics card. On the front side, the GPU direct touch heat-pipes combine a metal base plate to dissipate heat from the GPU and VRAM. On the back side, the copper back plate dissipates the heat from the GPU back side. All other key components are taken care of very well by the WINDFORCE cooling module. AORUS ensures the customer a better cooling solution in many ways. The metal back plate offers rigidity and protection to the structure, while adding a sleek, clean look to the product.
  • AORUS all-around cooling solution
  • Stylish metal back plate
Gigabyte AORUS Radeon RX570 4G - graphics card - Radeon RX 570 - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon RX 570 - up to
4 GB GDDR5
Core Clock
1295 MHz
Effective Memory Clock
7000 MHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
5
Interfaces Details
HDMI , 3 x DisplayPort , DVI-D (dual link)
API Supported
DirectX 12, OpenGL 4.5
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon RX 570
Core Clock
1295 MHz
Process Technology
14 nm
VR Ready
Max Resolution
7680 x 4320
5
Interfaces Details
API Supported
AMD Eyefinity Technology, GIGABYTE WindForce 2x, AMD CrossFireX Technology, FreeSync Technology, AMD VR Ready Premium, AMD XConnect Technology, 90mm Unique blade fan design, AORUS Graphics Engine
Size
4 GB
GDDR5 SDRAM
Effective Clock Speed
7000 MHz
Bus Width
256-bit
Required Power Supply
450 W
Additional Requirements
8 pin PCI Express power connector
AORUS metal sticker
