AORUS provides the all-around cooling solution for all key components of the graphics card. On the front side, the GPU direct touch heat-pipes combine a metal base plate to dissipate heat from the GPU and VRAM. On the back side, the copper back plate dissipates the heat from the GPU back side. All other key components are taken care of very well by the WINDFORCE cooling module. AORUS ensures the customer a better cooling solution in many ways. The metal back plate offers rigidity and protection to the structure, while adding a sleek, clean look to the product.
AORUS all-around cooling solution
AORUS provides the all-around cooling solution for all key components of the graphics card. On the front side, the GPU direct touch heat-pipes combine a metal base plate to dissipate heat from the GPU and VRAM. On the back side, the copper back plate dissipates the heat from the GPU back side. All other key components are taken care of very well by the WINDFORCE cooling module. AORUS ensures the customer a better cooling solution in many ways. -
Stylish metal back plate
- Gigabyte AORUS Radeon RX570 4G - graphics card - Radeon RX 570 - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon RX 570 - up to
- Memory
- 4 GB GDDR5
- Core Clock
- 1295 MHz
- Effective Memory Clock
- 7000 MHz
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 5
- Interfaces Details
- HDMI , 3 x DisplayPort , DVI-D (dual link)
- API Supported
- DirectX 12, OpenGL 4.5
- Graphics card
- Bus Type
- Graphics Engine
- AMD Radeon RX 570
- Core Clock
- 1295 MHz
- Process Technology
- 14 nm
- VR Ready
- Max Resolution
- 7680 x 4320
- 5
- API Supported
- AMD Eyefinity Technology, GIGABYTE WindForce 2x, AMD CrossFireX Technology, FreeSync Technology, AMD VR Ready Premium, AMD XConnect Technology, 90mm Unique blade fan design, AORUS Graphics Engine
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7000 MHz
- Bus Width
- 256-bit
- Required Power Supply
- 450 W
- Additional Requirements
- 8 pin PCI Express power connector
- Included Accessories
- AORUS metal sticker
