Gigabyte MW50-SV0 Intel C612 Chipset Server Board
Quicklinx: B5CSWS00 Mfr#: MW50-SV0
Based on the Haswell microarchitecture, the Intel processor families bring a set of performance boosting features. In addition to the usual boost in frequencies and core numbers, the Intel Xeon is the first in the industry to support the DDR4 memory technology. Moreover, the processors include encryption performance overhead reduction features, and technologies improving run time and migration VM integrity.
On the previous server platforms from Intel, the maximum supported memory frequency has always been automatically downgraded by design when more DIMMs were being added on a server motherboard. As this trade-off between performance and capacity represents a dilemma to many memory-hungry server applications, GIGABYTE offers a unique solution.
  • Intel Xeon processor
  • Memory frequency get the performance edge
    On the previous server platforms from Intel, the maximum supported memory frequency has always been automatically downgraded by design when more DIMMs were being added on a server motherboard. As this trade-off between performance and capacity represents a dilemma to many memory-hungry server applications, GIGABYTE offers a unique solution. The motherboards based on the LGA 2011-3 socket support by default a maximum frequency of 2133 MHz in any memory configuration.
  • Add-on SAS card storage flexibility
    In addition to its ten SATA III 6 Gb/s ports, the MD3O-RSO has eight SAS 6 Gb/s ports that can be activated with the addition of proprietary CRA220-8 add-on RAID card.
  • IR power design
    The board's CPU and memory power delivery is ensured by industry-leading IR digital PWM. The components guarantee a super stable operating environment and allow the processors and the memory to deliver their maximum performance.
  • High end ferrite core chokes
    The top quality chokes also contribute to an ultra stable power delivery to the CPU and the memory.
Gigabyte MW50-SV0 - 1.0 - motherboard - ATX - LGA2011-v3 Socket - C612
Motherboard - ATX
Chipset Type
Intel C612
Processor Socket
1 x LGA2011-v3 Socket
Compatible Processors
Xeon E5-2600 v3 series, Xeon E5-1600 v3 series
Max RAM Size
512 GB
RAM Supported
8 DIMM slots - DDR4, ECC, registered, Load-Reduced
Storage Ports
12 x SATA-600 (RAID), 2 x SATA-600
USB / FireWire Ports
5 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
3 x Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel C612
Processor Socket
LGA2011-v3 Socket
Max Processors Qty
1
Supported RAM
Max Size
512 GB
DDR4
Bus Clock
1600 MHz, 1866 MHz, 2133 MHz
Supported RAM Integrity Check
ECC
Registered or Buffered
Registered, Load-Reduced
Single rank, dual rank, quad channel memory architecture, quad rank
Details
256 GB - registered - ECC , 512 GB - Load-Reduced - ECC
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Interfaces
Expansion Slots
1 x CPU , 8 x DIMM 288-pin , 2 x PCIe 3.0 x16 , 1 x PCIe 3.0 x16 (x8 mode) , 1 x PCIe x4 , 1 x PCI
Storage Interfaces
SATA-600 -connectors: 8 x 7pin Serial ATA - 8 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 1 x 7pin SATA, 1 x mSATA , Marvell 88SE9230: SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10
3 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 4 x USB 3.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK , 1 x PS/2 keyboard / mouse , 1 x serial
Internal Interfaces
2 x USB 2.0 - header , 1 x USB 3.0 - Type A , 2 x USB 3.0 - header , 1 x audio - header , 1 x SPDIF in - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
Hardware Features
Intel Active Management Technology (Intel AMT), NVIDIA 3-way SLI Technology Support, NVIDIA 2-way SLI Technology Support, AMD CrossFireX technology support, AMD 3-way CrossFireX technology support, Clear CMOS Button
I/O back plate
2 x Serial ATA cable , 1 x SLI bridge , 1 x CrossFire internal bridge , 1 x 3-way SLI bridge
30.5 cm
24.4 cm
