Gigabyte M7600 Wireless Mouse
Quicklinx: 9R1CWS00 Mfr#: GM-M7600
Equipped with GIGABYTE precise optical tracking system and reliable 2.4GHz wireless transmission technology, the mouse is so responsive and easy to control. You'll find it hard to resist the charm! M7600 stays true to one of GIGABYTE's core concepts - ergonomic design. The mouse is designed exclusively for right-hand users. Rubber grip topped it off with the extraordinary hand-feeling, that is already more than satisfying to users.
  • GIGABYTE precise optical tracking system
  • 800/ 1600 on-the-fly DPI adjustable
  • Personalize your mouse with GIGABYTE SIM software
  • Stylish design and comfortable grip
  • Reliable 2.4GHz wireless transmission
    2.4GHz wireless provides 10m effective working distance. Let your work more efficient.
  • 800/1600 DPI switcher
    The DPI adjuster allows you change the resolution easily.
  • Total comfort ergonomic design
    You can experience perfect handle with rubber grip, especially suitable for large hand.
  • Optical tracking
    Not only able to work on virtually surface and accurate tracking.
  • Portable nano receiver
    The nano receiver is so tiny that you can keep plugging it into your notebook even when you are on the move.
Gigabyte GM-M7600 - mouse - RF - black
Mouse
Wireless - RF
6.6 cm x 10.9 cm x 3.9 cm
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
4
Movement Resolution
1600 dpi
2 x AAA type
Microsoft Windows 98/ME/2000/XP, Microsoft Windows Vista
Mouse
Wireless Receiver
6.6 cm
10.9 cm
3.9 cm
Input Device
Wireless
RF
Max Operating Distance
Up to 10 m
Optical
Buttons Qty
4
Movement Resolution
1600 dpi
1 x USB - 4 pin USB Type A
Plug and Play, BSMI, FCC, Laser Class 1
AAA type
Installed Qty
2
