Gigabyte M7000 Mini Notebook Mouse
Quicklinx: 9R0ZWS00 Mfr#: GM-M7000
Gigabyte GM-M7000 has its advantage of smaller size which is absolutely suitable for notebook users. The surface is not only ergonomic but also fashionable. People will be noticed of your sense of beauty while seeing this mini mouse.
With this technology, mouse can achieve higher intensity light without disperse for advanced precision. You can work on photo paper, coating, painting papers, even on glass boards.
The Gigabyte GM-M7000 features ergonomic design: comfort grip, finger grooves, and contoured shape give you more support and control with either hand.
  • Dual lens
    Dual lens features dual lens solution for advanced precision.
  • Ergonomic design
    Ergonomic design comfort grip, finger grooves, and contoured shape give you more support and control with either hand.
  • Super-smooth feet
    Slide easily across almost any surface.
  • Ambidextrous
    It is comfortable with either hand.
Gigabyte GM-M7000 - mouse - USB
Mouse
Wired - USB
Orientation
Right and left-handed
5.7 cm x 9.7 cm x 3.7 cm
81 g
Movement Detection Technology
Optical
Buttons Qty
4
Movement Resolution
1600 dpi
Performance
3000 fps
Dual lens
1 x USB cable - integrated - 1.5 m
Microsoft Windows 98/ME/2000/XP, Microsoft Windows Vista
Mouse
Orientation
5.7 cm
9.7 cm
3.7 cm
81 g
Input Device
Wired
USB
Optical
Buttons Qty
4
Movement Resolution
1600 dpi
Performance
3000 fps
Dual lens
1 x USB - 4 pin USB Type A
BSMI, FCC
