- 6000dpi gaming-grade laser sensor
- Built-in GHOSTTM Engine supports 3 macro profiles on the go
- Tracking capability and image processing up to 12000fps
- 4-direction tilt wheel functionality
Powered by 6000dpi Advanced Gaming Laser Sensor
Professional-grade laser sensor offers lightning fast 12,000 fps image processing capability for absolute control and precise mouse movement.
*Standard mice has 3000 FPS image processing capability
Built-in GHOSTTM Macro Engine
GHOSTTM macro engine which features intuitive interface allows you to pre-define up and switch between 9 programmable buttons easily for latest PC gaming titles. Onboard memory supports 3 macro profiles memorization for the gamer on the go.
4-direction Tilt Wheel Functionality
Versatile 4-direction tilt wheel for quick and easy desktop navigation. They are also programmable through GHOSTTM engine software.
*You may have to download GHOST engine software first to enjoy the complete function.
3-Stage DPI Adjustment
800/1600/5600 3-Stage DPI adjustable switch with 3-Stage LED indicators for quick on-the-fly DPI adjustment
*The hardware based sensitivity up to 5600dpi and software enhanced up to 6000dpi.
Anti-slick Rubber Grip with Ideal Shape for comfortable Gameplay
Anti-slick ergonomic rubber grip reduces wrist strain and maximizes comfort during extended use.
Ultra-durable USB Cable
1.8M ultra durable cable with gold plated USB connector ensures stable and optimum signal transfer.
Non-slick Coating
Moisture-resistant non-slick coating for exceptional comfort during extended gameplay sessions.
Gaming Grade Feet Pads
Teflon gaming grade feet pads for improved accuracy and freedom of movement.
Powered by 6000dpi advanced gaming laser sensor
Professional-grade laser sensor offers lightning fast 12,000 fps image processing capability for absolute control and precise mouse movement. -
Built-in GHOST macro engine
GHOST macro engine which features intuitive interface allows you to pre-define up and switch between 9 programmable buttons easily for latest PC gaming titles. Onboard memory supports 3 macro profiles memorization for the gamer on the go. -
Versatile 4-direction tilt wheel for quick and easy desktop navigation. They are also programmable through GHOST engine software. -
3-Stage DPI adjustment
800/1600/5600 3-Stage DPI adjustable switch with 3-Stage LED indicators for quick on-the-fly DPI adjustment -
Anti-slick rubber grip with ideal shape for comfortable gameplay
Anti-slick ergonomic rubber grip reduces wrist strain and maximizes comfort during extended use. -
Ultra-durable USB cable
1.8M ultra durable cable with gold plated USB connector ensures stable and optimum signal transfer. -
Non-slick coating
Moisture-resistant non-slick coating for exceptional comfort during extended gameplay sessions. -
Gaming grade feet pads
- Gigabyte M6980X - mouse - USB - black
- Mouse
- Connectivity Technology
- Wired - USB
- Black
- 7.76 cm x 12.45 cm x 4.18 cm
- 106 g
- Movement Detection Technology
- Laser
- Movement Resolution
- 6000 dpi
- Performance
- 30 G maximum acceleration, 12000 fps, 150 inches per second
- Scrolling wheel, golden USB plug
- Cables Included
- 1 x USB cable - integrated - 1.8 m
- OS Required
- Microsoft Windows Vista / XP / 7
- Mouse
- 7.76 cm
- 12.45 cm
- 4.18 cm
- 106 g
- Black
Input Device
- Wired
- Interface
- USB
- Laser
- Memory
- 8 KB
- 6000 dpi
- Performance
- 1 x USB - 4 pin USB Type A
- Cables Included
- BSMI, FCC
- OS Required
