Gigabyte M6900 Optical Gaming Mouse - 7 button - USB - black
Quicklinx: 7PG2WS00 Mfr#: M6900
Recommended Use: Gaming, Leisure
Type: Mouse
Wired / Wireless: Wired
Colour: Black
Compatibility: PC
£15.24 ex VAT
£18.28 inc VAT
Precision Optical Gaming Mouse
On-the-fly DPI Switching with LED display
3 stage DPI indicator (default 800dpi/1600dpi/2000dpi) (customizable 400~3200dpi adjustment via software)
GIGABYTE FORCE application
Simple drag-down menu enables user to set up mouse function depending on personal requirement
Gaming-grade Rubber
Comfortable texture with sweat-proof design provides a non-slip grip.
Gold-plated USB connector
1.8m strengthened cable customized for professional gamer
4 way tilt-wheel scrolling provides more functionality and more application
Highlights
3200dpi precise optical sensor
30G acceleration ensures the best performance during rapid movements
On-the-fly DPI switching with 3 stage red LED light indicator
Gaming-grade rubber provides a non-slip grip
Gigabyte M6900 - mouse - USB - black
Mouse
Wired - USB
7.8 cm x 12.5 cm x 4.2 cm
106 g
Movement Detection Technology
Optical
Buttons Qty
7
Movement Resolution
3200 dpi
Performance
30 G maximum acceleration, up to 65 inches per second, realtime sensitivity switching 800/1600/3200 dpi, 3600 fps
Scrolling wheel (4-way), golden USB plug, on-the-fly DPI switching with 3 stage red LED light indicator, gaming-grade rubber
1 x USB cable - integrated - 1.8 m
Microsoft Windows 98/2000/ME/XP/Vista/7
Mouse
7.8 cm
12.5 cm
4.2 cm
106 g
Input Device
Wired
USB
Optical
Buttons Qty
7
Movement Resolution
3200 dpi
Performance
1 x USB - 4 pin USB Type A
BSMI, FCC
Software Included
Drivers & Utilities
Recommended Use: Leisure
Type: Mouse
Colour: Black
Compatibility: PC
Brand: Gigabyte
Price Range Ex VAT: 0 - 50
