Gigabyte M6880X 1600dpi Gaming Mouse
Quicklinx: 9R1FWS00 Mfr#: M6880X
High accuracy laser engine offers consistent and reliable performance for absolute control and precise mouse movement. Equipped improved laser sensor, M6880X allows you to hit the target precisely.
  • Powered by 1600dpi accuracy laser sensor
  • 3-Stage DPI adjustment
    800/1200/1600 3-Stage DPI adjustable switch for quick on-the-fly DPI adjustment.
  • Anti-slick rubber grip with ideal shape for comfortable gameplay
    Anti-slick ergonomic rubber grip and matt coating surface reduce wrist strain and maximize comfort during extended use.
  • Forward and backward buttons
    Enjoy quickly browsing your favorite webpages or surfing throughout documents via the back and forward buttons which just located conveniently under your thumb.
  • Optimal lifting weight
    Perfect weight offers ideal lifting weight and friction in the frenzy gameplay.
  • 5 million clicks lifetime Omron switch
    Ultra-durable 5 million clicks Omron switches not only extend the durability and also perfect the clicking response.
  • Gaming grade feet pads
    Ultra-smooth Teflon gaming grade feet pads for improved accuracy and freedom of movement.
Gigabyte M6880X - mouse - USB - matte black
Mouse
Wired - USB
Matte black
Orientation
Right-handed
7.5 cm x 12.7 cm x 4.2 cm
100 g
Movement Detection Technology
Laser
Buttons Qty
5
Movement Resolution
1600 dpi
Performance
Realtime sensitivity switching 800/1200/1600 dpi, 125 reports per second, 6600 fps, 30 inches per second, 9 G maximum acceleration
Soft rubber grip, scrolling wheel, Teflon feet
Cable Length
1.5 m
Microsoft Windows Vista / XP / 7 / 8
Mouse
Orientation
Right-handed
7.5 cm
12.7 cm
4.2 cm
100 g
Matte black
Input Device
Wired
USB
Laser
Buttons Qty
5
Movement Resolution
1600 dpi
Performance
Cable Length
1.5 m
1 x USB - 4 pin USB Type A
BSMI, FCC, KCC
