As an unseen player, monitor is often being underestimated. The truth is that monitors form as a synergistic effect and bring out advanced performance of PC components. GIGABYTE gaming monitors offer the ultimate specifications and quality, users can truly enjoy upscale performance without the need for extravagance.
One For All
KVM feature allows you to control multiple devices via one set of keyboard, video and mouse. With our exclusive KVM button, you’ll find switching devices cannot be any easier! Quick like a snap
Performance
1ms GTG Response Time - The SuperSpeed IPS technology reduces the response time to 1ms GTG; meanwhile offering the IPS-grade splendid color!
QHD & 165Hz (OC 170Hz) - High resolution and fast refresh rate, giving you the detailed display quality and fluid gaming experience!
94% DCI-P3 - Fantastic color display and 94% DCI-P3 super wide-gamut color.
SIMPLE BUT STYLISH
The streamline appearance represents the simplicity of the GIGABYTE gaming series design philosophy, sturdy stand and matte finish built for functional and aesthetic features adding more to the characteristics.
Gaming Features
OSD Sidekick - GIGABYTE OSD Sidekick allows you to set the display options with keyboard and mouse, giving you the easiest way to adjust monitor settings.
Timer - Onscreen timer will assist you on tracking the elapsed game time.
PIP / PBP - The PIP and PBP functions allow users to view different video sources which are presented in one screen at the same time, you are able to watch the game guides at the same time using only one monitor!
HDR Mode - Besides default HDR settings, now you get to enjoy game and movie mode and even create your settings! Moreover, it supports HLG (Hybrid Log-Gamma), allowing you to truly enjoy the content originally created by broadcasting platform such as BBC iPlayer, NHK TV etc.
Eagle Eye With 3 sizes (small, medium and large) and 4 ratios (1.5x, 2.0x, 3.0x and 4.0x) to adjust, Eagle Eye truly equips you with the finest weapon to beat the enemies! Having hard time aiming at the target? GIGABYTE’s eagle eye is the answer to your question!
Dashboard - The dashboard reveals your real-time hardware information including CPU voltages, clock speed, temperatures, etc. The best part is that it won’t be blocked by any games
Black Equalizer - This feature allows you to have more details of the dark side without overexposing the bright side at the same time.
HIGHER LEVEL OF CUSTOMIZED COLOR ADJUSTMENT - With the help of Six Axis Control, it’s able get to control six colors (red, green, blue, cyan, magenta, and yellow) individually. It allows you to more accurately display the color gamut on the monitor.
Auto-Update - Users can effortlessly enjoy the finest gaming experience with features GIGABYTE continues to develop and upgrade while giving extra protection to your monitor.
Tech Features
Flicker Free - Preventing eye strain and fatigue
Clear Sound - Offering the quality sound experience
Eye Safe - Certified to meet the standard for colour balance and blue light reduction
Perfect Viewing Angle
An exclusive stand that's ergonomically designed to offer extensive range of height and tilt adjustments.
Swivel: -30 to +30 Degrees
Height Adjustment: 130mm
Tilt: -5 to +20 Degree
One for all
KVM feature allows you to control multiple devices via one set of keyboard, video and mouse. With an exclusive KVM button, you'll find switching devices cannot be any easier! Quick like a snap! -
Fast response times
The SuperSpeed IPS technology reduces the response time to 1ms GTG, meanwhile offering the IPS-grade splendid color! -
Simple but stylish
The streamline appearance represents the simplicity of the GIGABYTE gaming series design philosophy, sturdy stand and matte finish built for functional and aesthetic features adding more to the characteristics. -
OSD Sidekick
GIGABYTE OSD Sidekick allows you to set the display options with keyboard and mouse, giving you an easy way to adjust monitor settings. -
Flicker-Free
Flicker-Free technology prevents eye strain and fatigue. -
Ergonomic design
GIGABYTE gaming monitor features an exclusive stand that's ergonomically designed to offer extensive range of height and tilt adjustments. -
Counter
The gaming counter will help you calculate the time more easily. -
Auto update
Users can effortlessly enjoy the finest gaming experience with features GIGABYTE continues to develop and upgrade while giving extra protection to your monitor. -
Higher level of customized color adjustment
With the help of Six Axis Control, it's able get to control six colors individually. It allows you to more accurately display the color gamut on the monitor. -
Black equalizer
- Gigabyte M32Q - LED monitor - 32"
- LED-backlit LCD monitor - 32"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/406126
- Energy Class
- Class G
- Power Consumption (On mode)
- 40 W
- USB 3.0 hub
- Panel Type
- SS IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 165 Hz
- Pixel Pitch
- 0.273 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 1 ms (grey-to-grey), 0.8 ms (MPRT)
- Colour Gamut
- 120% sRGB, 94% DCI-P3
- Input Connectors
- 2xHDMI, DisplayPort, USB-C
- Height, swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100-240 V (50 - 60 Hz)
- 71.53 cm x 24.43 cm x 58.53 cm
- 10.2 kg
- DisplayPort 1.2
- Display Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- Diagonal Size
- 32"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- SS IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.273 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- Edge-lit LED
- Black eQualizer, Flicker Free technology, Crosshair Display, 8-bit Colour Depth, AORUS OSD Sidekick
- 71.53 cm x 24.43 cm x 58.53 cm - with stand
- 10.2 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
- 2 x HDMI , DisplayPort , Headphones , USB 3.0 upstream , 3 x USB 3.0 downstream , USB-C (KVM option)
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 60
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- DisplayPort 1.2
- Security Slot Type
- Kensington security slot
- Input Voltage
- 40 W
- Power Consumption SDR (On mode)
- 40 kWh/1000h
- Power Consumption HDR (On mode)
- 55 kWh/1000h
- Power Consumption (Max)
- 120 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 71.53 cm - depth: 24.43 cm - height: 58.53 cm - weight: 10.2 kg , Without stand - width: 71.58 cm - depth: 6.82 cm - height: 42.38 cm - weight: 7.1 kg
- Shipping Width
- 95.8 cm
- Shipping Depth
- 19.6 cm
- Shipping Height
- 55.4 cm
- Shipping Weight
- 13.6 kg
