The Aivia Krypton gaming mouse features a revolutionary new dual mouse chassis design which allows for a hot-swappable mouse chassis giving the user unparalleled freedom by changing fundamental mouse movement and dynamics to best fit the application at hand.
Aivia Krypton further enables maximum control and flexibility by giving users the option to customize the center of gravity and weight of the mouse. GHOST Macro engine with built-in 32KB memory for onboard Macro memorization and gaming on the go.
Hot Swappable Mouse Chassis
Dual Mouse chassis design which allows for a hot swappable mouse chassis gives the user unparalleled freedom by changing fundamental mouse movement and dynamics to best fit the application at hand.
Speed Chassis
The Speed Chassis features an abrasion-free ceramic foundation focused on quick movements, immediate reaction, and extraordinary speed.
Control Chassis
The Control Chassis utilizes an ultra smooth Teflon foundation which ensures precision movements for maximum control.
Customizable Center of Gravity
Revolutionary weight distribution system allows user to adjust the center of gravity for maximum control and flexibility.
Weight Adjustment Case
1.8g/5.3g weights allows you to adjust to the optimal weigh and balance
Weigh increase 1.8g ~ 39g
35 weight adjustable combination
Intuitive GHOST Macro Engine
GHOST macro engine which features intuitive interface allows you to pre-define and switch between keys or buttons easily for latest PC gaming titles.
5 gaming profiles on the go
Profile switch at your fingertips enables you to switch between 5 different gaming profiles. Up to 70 macros memorization for the gamer on the go.
Top of the line laser sensor
Advanced laser sensor supports up to 8200dpi resolution and 150ips tracking speed.
Quick switch between right-hand and left-hand mode
Press and hold both profile switch buttons for 3 seconds, the mouse will be switched between Left-Hand and Right-Hand operation modes.
- Gigabyte KRYPTON Aivia - mouse - USB - black
- Mouse
- Connectivity Technology
- Wired - USB
- Black
- 6.7 cm x 12.8 cm x 4.15 cm
- 110 g
- Movement Detection Technology
- Laser
- Movement Resolution
- 8200 dpi
- Performance
- 30 G maximum acceleration, 12000 fps, 150 inches per second
- Golden USB plug, GHOST Engine, status led, nylon braided cord
- Cables Included
- 1 x USB cable - integrated - 1.8 m
- OS Required
- Microsoft Windows Vista / XP / 7
- Mouse
- 6.7 cm
- 12.8 cm
- 4.15 cm
- 110 g
- Black
Input Device
- Wired
- Interface
- USB
- Laser
- Memory
- 32 KB
- 8200 dpi
- Performance
- 1 x USB - 4 pin USB Type A
- Included Accessories
- Weight modules with case, mouse feet, interchangeable mouse chassis
- Cables Included
- BSMI, FCC, KCC
- Software Included
- GHOST Macro Engine
- OS Required
