Gigabyte K8100 Aivia Gaming Keyboard
Quicklinx: 7PFWWS00 Mfr#: GK-K8100
K8100 Aivia
Coinciding with the concept of Aivia about advanced, intuitive, and versatile interface archetype, the K8100 is born to satisfy gamers' request. Aivia K8100 is equipped with three different levels of elastic force, touch and slide volume control, 20 non-Ghosting keystroke capability and GHOSTTM Macro Engine.
- Enhanced Ergonomic Gaming Keyboard Design- 3 different levels of force
- Touch and Slide Volume Control
- 20 Anti-Ghosting Keys
- GHOSTTM Macro Engine
- LED Backlight Illumination with On/Off Switch
- 2 USB 2.0 HUB
- Gold Plated USB Connector
- Durable Braided Cotton Cord
  • 20 anti-ghost keys
    It features pressing up to 20 simultaneous buttons without lost any key.
  • Touch and slide volume control
    It provides interruption free volume control device during engaged gaming activity. Keep sensor from far right or far left pressed, volume will increase or decrease linearly.
Gigabyte Aivia K8100 - keyboard
Keyboard - ergonomic
USB
Wired
Hot Keys Function
Volume, macros buttons
Rubber coated WASD gaming keys, 2-port USB 2.0 hub, profiles support, GHOST Macro Engine, volume control sensor, braided cotton cable
Image Colour Disclaimer
The displayed product image may be a different colour
26.3 cm x 49 cm x 3.3 cm
1.3 kg
USB
Input Device
Hot Keys Function
Anti-ghosting
26.3 cm
49 cm
3.3 cm
1.3 kg
2 x USB 2.0
Protective cover
1 x USB cable
BSMI, FCC, KCC
Included Software
GHOST Macro Engine
Microsoft Windows 98, Microsoft Windows 2000, Microsoft Windows Millennium Edition, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
-5 °C
10 - 90%
