Gigabyte H81M-HD3 S1150 Intel H81 DDR3 mATX
Quicklinx: 95NMWS00 Mfr#: GA-H81M-HD3
Gigabyte Ultra Durable 4 Plus debuts on Gigabyte 8 series motherboard, with a range of features and component choices that provide record-breaking performance, cool and efficient operation and extended motherboard lifespan.
4K resolution is the technological milestone in high-definition content delivery, utilizing approximately 4,000 pixels on the horizontal axis, more than four times today's standard HD pixel density. Gigabyte 8 series motherboard provides native 4K support with integrated Intel HD graphics via HDMI or DisplayPort.
  • Gigabyte Ultra Durable 4 Plus
  • Ultra performance
    Gigabyte uses all solid caps (capacitors) and low RDS (on) MOSFETs which are rated to work at higher temperatures to provide a longer lifespan.
  • Gigabyte UEFI DualBIOS
    Gigabyte motherboard features Gigabyte DualBIOS, an exclusive technology from Gigabyte that protects arguably one of your PC's most crucial components, the BIOS. Gigabyte DualBIOS means that your motherboard has both a 'main BIOS' and a 'backup BIOS', making users protected from BIOS failure due to virus attack, hardware malfunction, improper OC settings or power failure during the update process.
  • 4K Ultra HD support
  • DisplayPort support
    Gigabyte motherboard features DisplayPort, a graphics display interface that delivers up to 10.8 Gbps of bandwidth over standard cables, providing billions of colors with the fast refresh rates and the great color depths.
  • HDMI - the multimedia interface
    HDMI is a High-Definition Multimedia Interface which provides up to 5 Gbps video transmitting bandwidth and 8-channel high quality audio all through a single cable. Able to transmit superior, uncompressed digital video and audio, HDMI ensures the crisp rendering of digital content up to 1080p without the quality losses associated with analog interfaces and their digital-to-analog conversion.
  • DVI support
    DVI (Digital Visual Interface) is a video interface standard designed for carrying uncompressed digital video data and to maximize the visual quality of digital display devices, such as LCD monitors, digital projectors, and so on. In addition, the DVI interface is compatible with HDCP (High-bandwidth Digital Content Protection).
  • On/Off Charge technology
    Gigabyte On/Off Charge technology allows you to charge your iPhone, iPad and iPod Touch regardless of whether your PC is on, in standby mode or even off. A derivative of Gigabyte's highly acclaimed 3x USB power feature, On/Off Charge enables devices to draw more current from Gigabyte motherboard USB ports than standard USB ports allow, so that charging from your PC can be as fast as with a charger.
  • LAN Optimizer - intelligent optimization network management tool
    Gigabyte LAN Optimizer is designed to allow the user to manage different types of network traffic so that data streams such as HD media, web browsing or online gaming can be prioritized, taking precedence over large data downloads that tend to strangle overall network bandwidth.
  • Gigabyte EasyTune
    Simple and easy-to-use interface that allows users to fine-tune their system settings. Adjust system and memory clocks and voltages in a Windows environment. System-related information display without the need to install additional software.
  • Gigabyte Smart Fan 2
    As well as offering more system fans than ever before, Gigabyte 8 series motherboard features updated and improved CPU and system fan speed controls, with individual airflow and speed settings available via a dedicated digital controller. Gigabyte Smart Fan 2 allows you to configure CPU fans and system fans.
Gigabyte GA-H81M-HD3 - 1.0 - motherboard - micro ATX - LGA1150 Socket - H81
Motherboard - micro ATX
Chipset Type
Intel H81
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC
Storage Ports
2 x SATA-600, 2 x SATA-300
USB / FireWire Ports
4 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
Intel H81
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz
Supported RAM Integrity Check
Non-ECC
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1 GB
Audio
Audio Codec
Realtek ALC892
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
2 x DIMM 240-pin (1.5 V) , 1 x PCIe 2.0 x1 , 1 x PCIe 2.0 x16 , 2 x PCI
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices , SATA-300 -connectors: 2 x 7pin Serial ATA - 2 devices
1 x VGA , 1 x HDMI , 1 x DisplayPort , 1 x DVI-D , 4 x USB 3.0 , 2 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet) , 1 x TOSLINK , 1 x audio line-in - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack
Internal Interfaces
4 x USB 2.0 - header , 1 x audio - header , 2 x USB 3.0 - header , 1 x SPDIF in - header , 1 x SPDIF out - header , 1 x serial - header , 1 x parallel - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, CPU core voltage
Hardware Features
DualBIOS, Q-Flash, Intel Extreme Memory Profile (XMP) support, On/Off Charge, One Port One Fuse, GIGABYTE LAN Optimizer, ESD Protection, 4K Ultra HD ready, Ultra Durable 4 Plus, Clear CMOS Button
Software Included
Norton Internet Security, @BIOS, EasyTune, GIGABYTE EZ Setup, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center
Plug and Play, ACPI 2.0a
24.4 cm
19 cm
