Gigabyte GV-N1080XTREME-8GD - Premium Pack - graphics card - GF GTX 1080 - 8 GB
Quicklinx: CCTJWS00 Mfr#: GV-N1080XTREME-8GD-PP
The Xtreme Gaming series graphics cards are crafted for perfection in pursuit of amazing graphics experience for gaming enthusiasts. Based on an incredibly advanced architecture, Xtreme gaming graphics card bring you excellent gaming experience.
  • Advanced cooling system
    The cooling system features a special fan design, double ball bearing structure, angular fin design and composite heat pipes, together delivering an effective heat dissipation capacity for higher performance at lower temperatures.
  • Stack fan design
    The stack fans provide larger and smoother airflow. And with more heatsink coverage, these stack fans will have better cooling performance.
  • Special fan design
    The airflow is split by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the airflow.
  • Double ball bearing structure
    The double ball bearing structure has better heat endurance and efficiency than sleeve structure. Hence it will provide longer life time.
  • Composite heat pipes
    The composite heat pipes combine both thermal conductivity and phase transition for efficiently managing the transfer of heat between two solid interfaces which increases the cooling capacity.
  • Large copper base plate
    With direct contact to the GPU and VRAM, the large copper base plate combines the composite heat pipes to efficiently transfer heat generated from the interior cores to the heat sink, keeping the graphics card cool and stable for better performance.
Gigabyte GeForce GTX 1080 Xtreme Gaming - Premium Pack - graphics card - GF GTX 1080 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1080
8 GB GDDR5X
Core Clock
1759 MHz
Boost Clock
1784 MHz
Effective Memory Clock
10.416 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
5.6 cm x 28.9 cm x 13.8 cm
4 years warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1759 MHz
Boost Clock
1784 MHz
Process Technology
16 nm
VR Ready
Max Resolution
7680 x 4320 at 60 Hz
4
Interfaces Details
API Supported
Ultra Durable VGA, LED indicator, GIGABYTE WindForce 3x, Three Fans Cooler, Dual ball Bearing Fan, NVIDIA G-Sync ready, NVIDIA GameWorks, 0dB semi-passive fans, Nvidia GeForce GTX VR Ready
Size
8 GB
GDDR5X SDRAM
Effective Clock Speed
10.416 GHz
Bus Width
256-bit
Required Power Supply
500 W
Additional Requirements
2 x 8 pin PCI Express power connector
Dual 6-pin PCIe to 8-pin power cable, Xtreme gaming sticker, wrist protector, paper folder, XMP300 mouse pad, Xtreme VR Link extended bracket, Xtreme VR Link extended 5.25" front panel
1 x SLI bridge
5.6 cm
28.9 cm
13.8 cm
Limited warranty - 4 Years
