The GIGABYTE AORUS GeForce RTX 5090 MASTER ICE 32G graphics card is designed to elevate your gaming experience with performance and features. Equipped with 32 GB of GDDR7 VRAM and a 512-bit bus width, this graphics card delivers graphics and smooth gameplay, supporting resolutions up to 7680 x 4320. The NVIDIA GeForce RTX 5090 processor, combined with a clock speed of 2655 MHz, ensures that demanding games run across multiple monitors, up to four at once. With support for DirectX 12 and OpenGL 4.6, gamers can enjoy the visuals and detailed environments offered by current titles.
Enhanced by GIGABYTE’s WINDFORCE cooling design, this graphics card features thermal management with dual ball bearing fans, moisture and dust resistance, and server-grade thermal conductive gel for efficiency during intense gaming sessions. With programmable RGB lighting and an LCD Edge View, the AORUS GeForce RTX 5090 MASTER ICE integrates seamlessly into any build while allowing for personalization. The inclusion of essential accessories such as a VGA holder and a 16-pin to 4x 8-pin cable adapter adds convenience for installation.
High capacity memory
The graphics card features 32 GB of GDDR7 SDRAM, ensuring ample memory for high-resolution textures and graphical assets in demanding games. -
Robust cooling solutions
The GIGABYTE WINDFORCE cooling design incorporates dual ball bearing fans and specialized thermal gel, ensuring optimal performance without overheating. -
Multiple output options
With three DisplayPort connections and one HDMI port, this graphics card supports external displays, making it ideal for immersive gaming experiences. -
GPU architecture
Powered by the NVIDIA Blackwell GPU architecture, the graphics card includes support for features like DLSS 4, ray tracing, and Multi Frame Generation. -
Enhanced durability
Constructed with a metal reinforced backplate and a 2 oz copper PCB, this graphics card is built to withstand the rigors of intensive gaming and long hours of operation.
- AORUS GeForce RTX 5090 MASTER ICE 32G - OC Edition - graphics card - GeForce RTX 5090 - 32 GB
- Graphics card
- Bus Type
- PCI Express 5.0
- Graphics Engine
- NVIDIA GeForce RTX 5090
- Memory
- 32 GB GDDR7
- Memory Speed
- 28 Gbps
- Core Clock
- 2655 MHz
- CUDA Cores
- 21760
- Memory Interface
- 512-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.6
- 7.5 cm x 36 cm x 15 cm
- 4-year warranty with product registration
- Graphics card
- Bus Type
- PCI Express 5.0
- Graphics Engine
- Core Clock
- 2655 MHz
- CUDA Cores
- 21760
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- NVIDIA Blackwell GPU architecture, NVIDIA DLSS 4, NVIDIA G-Sync ready, NVIDIA Reflex 2, NVIDIA Multi Frame Generation, NVIDIA Frame Warp, NVIDIA Avatar Cloud Engine (ACE), 5th gen Tensor Cores, 4th gen Ray Tracing Cores, GIGABYTE WINDFORCE cooling design, Hawk Fan design, server-grade thermal conductive gel, LCD Edge View, GIGABYTE RGB Halo, Dual Bios, screen cooling plus, Gigabyte Alternate Spinning, Dual ball Bearing Fans, 3D Active Fan, RGB Lighting, metal reinforced backplate, LED indicator, Ultra Durable VGA, dust resistant, moisture resistant, corrosion resistant, 2oz copper PCB
- Size
- 32 GB
- Technology
- GDDR7 SDRAM
- Memory Speed
- 28 Gbps
- Bus Width
- 512-bit
- Required Power Supply
- 1000 W
- Additional Requirements
- 16 pin PCI Express power connector
- Included Accessories
- 16-pin to 4x 8-pin cable adapter, AORUS identity stickers, AORUS metal sticker, VGA Holder
- Software Included
- GeForce Game Ready Drivers, NVIDIA Studio drivers, Gigabyte Control Center
- DisplayPort 2.1b
- 7.5 cm
- 36 cm
- 15 cm
- Limited warranty - 3 years , Limited warranty - 4 years with product registration (within 30 days of purchase)
