Gigabyte GPU NV 5090 AORUS MASTER ICE 32G Fan
Quicklinx: J521WS00 Mfr#: GV-N5090AORUSM ICE-32GD
Graphics Processor Manufacturer: NVIDIA
Graphics Processor: NVIDIA GeForce RTX 5090
Interface: PCI Express 5.0
Memory Size: 32GB
Digital Output: High-Definition Multimedia Interface (HDMI), DisplayPort
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
Hurry, only 1 left in stock!
£2,124.17 ex VAT
£2,549.00 inc VAT
Express delivery Order within the next 15 hours for delivery tomorrow
The GIGABYTE AORUS GeForce RTX 5090 MASTER ICE 32G graphics card is designed to elevate your gaming experience with performance and features. Equipped with 32 GB of GDDR7 VRAM and a 512-bit bus width, this graphics card delivers graphics and smooth gameplay, supporting resolutions up to 7680 x 4320. The NVIDIA GeForce RTX 5090 processor, combined with a clock speed of 2655 MHz, ensures that demanding games run across multiple monitors, up to four at once. With support for DirectX 12 and OpenGL 4.6, gamers can enjoy the visuals and detailed environments offered by current titles.
Enhanced by GIGABYTE’s WINDFORCE cooling design, this graphics card features thermal management with dual ball bearing fans, moisture and dust resistance, and server-grade thermal conductive gel for efficiency during intense gaming sessions. With programmable RGB lighting and an LCD Edge View, the AORUS GeForce RTX 5090 MASTER ICE integrates seamlessly into any build while allowing for personalization. The inclusion of essential accessories such as a VGA holder and a 16-pin to 4x 8-pin cable adapter adds convenience for installation.
AORUS GeForce RTX 5090 MASTER ICE 32G - OC Edition - graphics card - GeForce RTX 5090 - 32 GB
Graphics card
Bus Type
PCI Express 5.0
Graphics Engine
32 GB GDDR7
Memory Speed
28 Gbps
Core Clock
2655 MHz
CUDA Cores
21760
Memory Interface
512-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.6
7.5 cm x 36 cm x 15 cm
4-year warranty with product registration
Graphics card
Bus Type
PCI Express 5.0
Graphics Engine
Core Clock
2655 MHz
CUDA Cores
21760
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
NVIDIA Blackwell GPU architecture, NVIDIA DLSS 4, NVIDIA G-Sync ready, NVIDIA Reflex 2, NVIDIA Multi Frame Generation, NVIDIA Frame Warp, NVIDIA Avatar Cloud Engine (ACE), 5th gen Tensor Cores, 4th gen Ray Tracing Cores, GIGABYTE WINDFORCE cooling design, Hawk Fan design, server-grade thermal conductive gel, LCD Edge View, GIGABYTE RGB Halo, Dual Bios, screen cooling plus, Gigabyte Alternate Spinning, Dual ball Bearing Fans, 3D Active Fan, RGB Lighting, metal reinforced backplate, LED indicator, Ultra Durable VGA, dust resistant, moisture resistant, corrosion resistant, 2oz copper PCB
Size
32 GB
GDDR7 SDRAM
Memory Speed
28 Gbps
Bus Width
512-bit
Required Power Supply
1000 W
Additional Requirements
16 pin PCI Express power connector
16-pin to 4x 8-pin cable adapter, AORUS identity stickers, AORUS metal sticker, VGA Holder
Software Included
GeForce Game Ready Drivers, NVIDIA Studio drivers, Gigabyte Control Center
DisplayPort 2.1b
7.5 cm
36 cm
15 cm
Limited warranty - 3 years , Limited warranty - 4 years with product registration (within 30 days of purchase)
Memory Size: 32GB
Digital Output: DisplayPort
Brand: Gigabyte
Price Range Ex VAT: £1500+
Stock Status: While stocks last
Stock Status: Clearance
