Gigabyte GeForce RTX 5070 GAMING OC 12GB
Quicklinx: J46NWS00 Mfr#: GV-N5070GAMING OC-12GD
The GIGABYTE GeForce RTX 5070 GAMING OC 12G graphics card combines performance and technology, ideal for gamers and content creators. Equipped with 12 GB of GDDR7 SDRAM and a 192-bit bus width, it delivers memory speed at 28 Gbps, enabling smooth gameplay and vibrant graphics. The NVIDIA GeForce RTX 5070 processor supports a maximum external resolution of 7680 x 4320 and allows for up to 4 monitors, providing visual experiences for advanced gaming setups or professional applications.
This model features a robust cooling system with GIGABYTE WINDFORCE design, a triple fan setup, and a Dual Bios for efficient temperature management and optimized performance. With technologies like NVIDIA DLSS 4 and NVIDIA Reflex, players can enjoy faster frames and improved responsiveness. The card also comes with RGB lighting through GIGABYTE RGB Halo, allowing for customization of lighting effects. Included accessories like a graphics card holder and a 2x8-pin to 12VHPWR cable ensure straightforward installation, making it a powerful addition to any PC build.
  • Advanced cooling system
    The GIGABYTE WINDFORCE cooling design features a triple fan setup that dissipates heat, ensuring the graphics card operates at optimal temperatures for peak performance.
  • High memory capacity
    With 12 GB of GDDR7 SDRAM and a memory speed of 28 Gbps, this graphics card provides the bandwidth needed for high-resolution textures and complex calculations in demanding applications.
  • Versatile connectivity options
    The card features multiple output ports including 3 x DisplayPort and HDMI, allowing users to connect a variety of display devices and achieve multiple monitor setups.
  • Support for high external resolution
    Maximize visual fidelity with support for an external resolution of 7680 x 4320, enabling immersive gaming experiences and professional video editing.
  • NVIDIA technologies
    Integrated with NVIDIA DLSS 4 and NVIDIA Reflex, this graphics card enhances frame rates and reduces latency, providing a smoother gameplay experience.
Gigabyte GeForce RTX 5070 GAMING OC 12G - graphics card - GeForce RTX 5070 - 12 GB
Graphics card
Bus Type
PCI Express 5.0
Graphics Engine
12 GB GDDR7
Memory Speed
28 Gbps
Memory Interface
192-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
3 x DisplayPort , HDMI
API Supported
OpenGL 4.6
3-year warranty
Graphics card
Bus Type
PCI Express 5.0
Graphics Engine
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
OpenGL 4.6
GIGABYTE WINDFORCE cooling design, Dual Bios, GIGABYTE RGB Halo, NVIDIA DLSS 4, NVIDIA Reflex, Nvidia Studio, Triple Fan Design
Size
12 GB
GDDR7 SDRAM
Memory Speed
28 Gbps
Bus Width
192-bit
Additional Requirements
16 pin PCI Express power connector
Graphics card holder, 2x8-pin to 12VHPWR cable
DisplayPort 2.1a
Limited warranty - 3 years , Limited warranty - extended warranty with product registration - 4 Years
