- Powered by NVIDIA DLSS 3, ultra-efficient Ada Lovelace arch, and full ray tracing
- 4th Generation Tensor Cores: Up to 4X performance with DLSS 3 vs. brute-force rendering
- 3rd Generation RT Cores: Up to 2X ray tracing performance
- Powered by GeForce RTX™ 4080 SUPER
- Integrated with 16GB GDDR6X 256-bit memory interface
- WINDFORCE Cooling System
- Dual BIOS
- Protection metal back plate
- Anti-sag bracket
Advanced cooling
The GIGABYTE GeForce RTX 4080 SUPER WINDFORCE V2 16G features the GIGABYTE WINDFORCE cooling design, incorporating 100 mm unique blade fan design, triple fan setup, and screen cooling to ensure optimal performance under heavy loads. -
Exceptional performance
Equipped with NVIDIA GeForce RTX 4080 SUPER graphics processor and 10,240 CUDA cores, this video card delivers a clock speed of 2550 MHz, coupled with 16 GB of GDDR6X SDRAM, making it suitable for high-resolution gaming and professional graphic tasks. -
High-quality visuals
Supporting DirectX 12 Ultimate and OpenGL 4.6, the card offers impressive visuals and is capable of driving up to 4 monitors with a maximum resolution of 7680 x 4320, providing an immersive gaming and viewing experience. -
Advanced technology
Features such as 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, NVIDIA DLSS 3, and NVIDIA Ada Lovelace GPU technology, ensure that users experience realistic graphics, with efficient performance and AI-enhanced gaming. -
Durability and support
The card includes an anti-sag bracket and a reinforced backplate, ensuring long-term durability and reliability. With support for DisplayPort 1.4a and HDMI, it offers versatile connectivity options for a wide range of displays.
- Gigabyte GeForce RTX 4080 SUPER WINDFORCE V2 16G - graphics card - NVIDIA GeForce RTX 4080 SUPER - 16 GB
- Graphics card
- Bus Type
- PCI Express 4.0 x16
- Graphics Engine
- NVIDIA GeForce RTX 4080 SUPER - up to
- Memory
- 16 GB GDDR6X
- Memory Speed
- 23 Gbps
- Core Clock
- 2550 MHz
- CUDA Cores
- 10240
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- 3 x DisplayPort ¦ HDMI
- API Supported
- DirectX 12 Ultimate, OpenGL 4.6
- 5.8 cm x 33 cm x 13.6 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 2550 MHz
- CUDA Cores
- 10240
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- NVIDIA Ada Lovelace GPU technology, 4th gen Tensor Cores, 3rd gen Ray Tracing Cores, Triple Fan Design, NVIDIA DLSS 3, GIGABYTE WINDFORCE cooling design, Dual Bios, reinforced backplate, Nvidia Studio, Nvidia Broadcast, NVIDIA Reflex, 100mm unique blade fan design, 3D Active Fan, composite copper heat pipes, Gigabyte Alternate Spinning, GPU direct contact copper plates, Graphene Nano Lubricant, screen cooling, large copper plate, Ultra Durable VGA
- Size
- 16 GB
- Technology
- GDDR6X SDRAM
- Memory Speed
- 23 Gbps
- Bus Width
- 256-bit
- Required Power Supply
- 750 W
- Additional Requirements
- 16 pin PCI Express power connector
- Included Accessories
- Anti-sag bracket, 16-pin to 3x 8-pin power adapter
- Software Included
- Gigabyte Control Center, GeForce Game Ready Drivers, NVIDIA Studio drivers
- DisplayPort 1.4a
- 5.8 cm
- 33 cm
- 13.6 cm
