- Powered by NVIDIA DLSS 3, ultra-efficient Ada Lovelace arch, and full ray tracing
- 4th Generation Tensor Cores: Up to 4X performance with DLSS 3 vs. brute-force rendering
- 3rd Generation RT Cores: Up to 2X ray tracing performance
- Powered by GeForce RTX™ 4080 SUPER
- Integrated with 16GB GDDR6X 256-bit memory interface
- WINDFORCE Cooling System
- RGB Fusion
- Dual BIOS
- Protection metal back plate
- Anti-sag bracket
Enhanced cooling
The GIGABYTE GeForce RTX 4080 SUPER AERO OC 16G features the GIGABYTE WINDFORCE cooling design, incorporating a 110 mm unique blade fan design, triple fan setup, and composite copper heat pipes to ensure optimal cooling performance under heavy loads. -
Superior performance
Equipped with NVIDIA GeForce RTX 4080 SUPER graphics processor and 10,240 CUDA cores, this video card delivers exceptional performance for gaming and creative work. The 16 GB GDDR6X SDRAM with a 256-bit bus width and a memory speed of 23 Gbps allows for smooth and fast data processing. -
Advanced gaming technologies
Leverage the power of 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, NVIDIA DLSS 3, and NVIDIA Reflex to experience enhanced gaming with improved realism, improved frame rates, and reduced latency. The support for DirectX 12 Ultimate and OpenGL 4.6 further enhances gaming compatibility and performance.
- Gigabyte GeForce RTX 4080 SUPER AERO OC 16G - OC Edition - graphics card - NVIDIA GeForce RTX 4080 SUPER - 16 GB
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- Memory
- 16 GB GDDR6X
- Memory Speed
- 23 Gbps
- Core Clock
- 2595 MHz
- CUDA Cores
- 10240
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- 3 x DisplayPort , HDMI
- API Supported
- DirectX 12 Ultimate, OpenGL 4.6
- 7.5 cm x 34.2 cm x 15 cm
- 4-year warranty with product registration
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- Core Clock
- 2595 MHz
- CUDA Cores
- 10240
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, NVIDIA Ada Lovelace GPU technology, Triple Fan Design, NVIDIA DLSS 3, GIGABYTE WINDFORCE cooling design, RGB fusion, Dual Bios, metal backplate, NVIDIA RTX Video Super Resolution, Nvidia Studio, Nvidia Broadcast, NVIDIA Reflex, 110mm unique blade fan design, composite copper heat pipes, Gigabyte Alternate Spinning, GPU direct contact copper plates, large copper plate, 3D Active Fan, screen cooling, Graphene Nano Lubricant, Ultra Durable VGA
- Size
- 16 GB
- Technology
- GDDR6X SDRAM
- Memory Speed
- 23 Gbps
- Bus Width
- 256-bit
- Required Power Supply
- 850 W
- Additional Requirements
- 16 pin PCI Express power connector
- Included Accessories
- Anti-sag bracket, 16-pin to 3x 8-pin power adapter
- Software Included
- GeForce Game Ready Drivers, NVIDIA Studio drivers, Gigabyte Control Center
- DisplayPort 1.4a
- 7.5 cm
- 34.2 cm
- 15 cm
- Limited warranty - 3 years , Limited warranty - 4 years with product registration (within 30 days of purchase)
