Gigabyte GeForce RTX 4070 Ti SUPER WINDFORCE OC 16G Graphics Card
Quicklinx: HX0CWS00 Mfr#: GV-N407TSWF3OC-16GD
The GIGABYTE GeForce RTX 4070 Ti SUPER WINDFORCE OC 16G video card is designed for gamers and professionals seeking high graphics performance and reliability. Featuring the GIGABYTE WINDFORCE cooling system, this card ensures optimal performance by efficiently dissipating heat through its triple fan design and composite copper heat pipes. With 16 GB of GDDR6X SDRAM and a memory speed of 21 Gbps, it delivers the bandwidth and speed required for high-resolution gaming and demanding applications. The card supports DirectX 12 Ultimate and OpenGL 4.6, enabling stunning visuals enhanced by 3rd gen Ray Tracing Cores and 4th gen Tensor Cores for realistic lighting and shadows. Innovative features such as NVIDIA DLSS 3, NVIDIA RTX Video Super Resolution, and NVIDIA Reflex, powered by NVIDIA Ada Lovelace GPU technology, offer high performance and efficiency. Additionally, its versatile connectivity options, including HDMI and DisplayPort, support up to 4 monitors with a max external resolution of 7680 x 4320, making it ideal for multi-display setups and high-resolution gaming or professional use.
  • Advanced cooling
    The GIGABYTE GeForce RTX 4070 Ti SUPER WINDFORCE OC 16G features the GIGABYTE WINDFORCE cooling design, incorporating triple fan design, composite copper heat pipes, and large copper plate to efficiently dissipate heat, ensuring optimal performance under heavy loads.
  • Exceptional graphics
    Equipped with NVIDIA GeForce RTX 4070 Ti SUPER graphics processor and supporting DirectX 12 Ultimate and OpenGL 4.6, this video card delivers stunning visuals, enhanced by 3rd gen Ray Tracing Cores and 4th gen Tensor Cores for realistic lighting and shadows.
  • High-speed memory
    With 16 GB of GDDR6X SDRAM and a memory speed of 21 Gbps, this video card provides ample bandwidth and speed for high-resolution gaming and demanding applications, ensuring smooth and immersive experiences.
  • Innovative features
    Features such as NVIDIA DLSS 3, NVIDIA RTX Video Super Resolution, and NVIDIA Reflex enhance gaming and content creation, supported by NVIDIA Ada Lovelace GPU technology for high performance and efficiency.
  • Versatile connectivity
    Supporting up to 4 monitors with a max external resolution of 7680 x 4320, and offering multiple output ports including HDMI and DisplayPort, this video card is ideal for multi-display setups and high-resolution gaming or professional use.
Gigabyte GeForce RTX 4070 Ti SUPER WINDFORCE OC 16G - graphics card - GeForce RTX 4070 Ti Super - 16 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
16 GB GDDR6X
Memory Speed
21 Gbps
Core Clock
2625 MHz
CUDA Cores
8448
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
3 x DisplayPort , HDMI
API Supported
DirectX 12 Ultimate, OpenGL 4.6
5 cm x 26.1 cm x 12.6 cm
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Core Clock
2625 MHz
CUDA Cores
8448
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
3rd gen Ray Tracing Cores, 4th gen Tensor Cores, NVIDIA DLSS 3, Triple Fan Design, GIGABYTE WINDFORCE cooling design, metal backplate, Nvidia Studio, NVIDIA Reflex, NVIDIA RTX Video Super Resolution, Nvidia Broadcast, Optical Flow Accelerator, Gigabyte Alternate Spinning, composite copper heat pipes, GPU direct contact copper plates, 3D Active Fan, screen cooling, Graphene Nano Lubricant, vented backplate, large copper plate, lower RDS MOSFETs, NVIDIA Ada Lovelace GPU technology
Size
16 GB
GDDR6X SDRAM
Memory Speed
21 Gbps
Bus Width
256-bit
Required Power Supply
750 W
Additional Requirements
16 pin PCI Express power connector
16-pin to 2x 8-pin power adapter
Software Included
NVIDIA GeForce Experience, Gigabyte Control Center
DisplayPort 1.4a
5 cm
26.1 cm
12.6 cm
