The GIGABYTE GeForce RTX 4070 Ti SUPER WINDFORCE OC 16G video card is designed for gamers and professionals seeking high graphics performance and reliability. Featuring the GIGABYTE WINDFORCE cooling system, this card ensures optimal performance by efficiently dissipating heat through its triple fan design and composite copper heat pipes. With 16 GB of GDDR6X SDRAM and a memory speed of 21 Gbps, it delivers the bandwidth and speed required for high-resolution gaming and demanding applications. The card supports DirectX 12 Ultimate and OpenGL 4.6, enabling stunning visuals enhanced by 3rd gen Ray Tracing Cores and 4th gen Tensor Cores for realistic lighting and shadows. Innovative features such as NVIDIA DLSS 3, NVIDIA RTX Video Super Resolution, and NVIDIA Reflex, powered by NVIDIA Ada Lovelace GPU technology, offer high performance and efficiency. Additionally, its versatile connectivity options, including HDMI and DisplayPort, support up to 4 monitors with a max external resolution of 7680 x 4320, making it ideal for multi-display setups and high-resolution gaming or professional use.
Advanced cooling
The GIGABYTE GeForce RTX 4070 Ti SUPER WINDFORCE OC 16G features the GIGABYTE WINDFORCE cooling design, incorporating triple fan design, composite copper heat pipes, and large copper plate to efficiently dissipate heat, ensuring optimal performance under heavy loads. -
Exceptional graphics
Equipped with NVIDIA GeForce RTX 4070 Ti SUPER graphics processor and supporting DirectX 12 Ultimate and OpenGL 4.6, this video card delivers stunning visuals, enhanced by 3rd gen Ray Tracing Cores and 4th gen Tensor Cores for realistic lighting and shadows. -
High-speed memory
With 16 GB of GDDR6X SDRAM and a memory speed of 21 Gbps, this video card provides ample bandwidth and speed for high-resolution gaming and demanding applications, ensuring smooth and immersive experiences. -
Innovative features
Features such as NVIDIA DLSS 3, NVIDIA RTX Video Super Resolution, and NVIDIA Reflex enhance gaming and content creation, supported by NVIDIA Ada Lovelace GPU technology for high performance and efficiency. -
Versatile connectivity
Supporting up to 4 monitors with a max external resolution of 7680 x 4320, and offering multiple output ports including HDMI and DisplayPort, this video card is ideal for multi-display setups and high-resolution gaming or professional use.
- Gigabyte GeForce RTX 4070 Ti SUPER WINDFORCE OC 16G - graphics card - GeForce RTX 4070 Ti Super - 16 GB
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- NVIDIA GeForce RTX 4070 Ti SUPER
- Memory
- 16 GB GDDR6X
- Memory Speed
- 21 Gbps
- Core Clock
- 2625 MHz
- CUDA Cores
- 8448
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- 3 x DisplayPort , HDMI
- API Supported
- DirectX 12 Ultimate, OpenGL 4.6
- 5 cm x 26.1 cm x 12.6 cm
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- Core Clock
- 2625 MHz
- CUDA Cores
- 8448
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, NVIDIA DLSS 3, Triple Fan Design, GIGABYTE WINDFORCE cooling design, metal backplate, Nvidia Studio, NVIDIA Reflex, NVIDIA RTX Video Super Resolution, Nvidia Broadcast, Optical Flow Accelerator, Gigabyte Alternate Spinning, composite copper heat pipes, GPU direct contact copper plates, 3D Active Fan, screen cooling, Graphene Nano Lubricant, vented backplate, large copper plate, lower RDS MOSFETs, NVIDIA Ada Lovelace GPU technology
- Size
- 16 GB
- Technology
- GDDR6X SDRAM
- Memory Speed
- 21 Gbps
- Bus Width
- 256-bit
- Required Power Supply
- 750 W
- Additional Requirements
- 16 pin PCI Express power connector
- Included Accessories
- 16-pin to 2x 8-pin power adapter
- Software Included
- NVIDIA GeForce Experience, Gigabyte Control Center
- DisplayPort 1.4a
- 5 cm
- 26.1 cm
- 12.6 cm
