Gigabyte GeForce RTX 4070 Ti SUPER EAGLE OC 16G Graphics Card
Quicklinx: HVHCWS00 Mfr#: GV-N407TSEAGLE OC-16GD
The GIGABYTE GeForce RTX 4070 Ti SUPER EAGLE OC 16G is a high-performance graphics card, designed for gamers and creators. It features 16 GB of GDDR6X SDRAM and a 256-bit memory interface, providing exceptional speed and bandwidth for demanding applications. The card's boost clock speed of 2640 MHz, along with NVIDIA's innovations such as DLSS 3, RTX Video Super Resolution, and Reflex, ensures smooth, high-quality gaming experiences. The GIGABYTE WINDFORCE cooling system, with a triple fan design, composite copper heat pipes, and a large copper plate, maintains optimal temperatures. Additional features like RGB fusion for customizable lighting and a durable metal backplate make it a visually striking addition to any setup. Suitable for gaming, content creation, or professional applications, the GeForce RTX 4070 Ti SUPER EAGLE OC 16G meets the needs of demanding users.
  • Enhanced Cooling Efficiency
    The GIGABYTE GeForce RTX 4070 Ti SUPER EAGLE OC 16G features the GIGABYTE WINDFORCE cooling design, incorporating a triple fan design, composite copper heat pipes, and a large copper plate, ensuring superior heat dissipation for sustained performance.
  • Advanced Gaming Technologies
    Equipped with NVIDIA Ada Lovelace GPU technology, 3rd gen Ray Tracing Cores, and 4th gen Tensor Cores, this video card delivers an advanced gaming experience with enhanced realism and performance.
  • Optimized for Creators
    With features like Nvidia Studio, Nvidia Broadcast, and support for multiple APIs including DirectX 12 Ultimate and OpenGL 4.6, this graphics card is not just for gaming but also optimized for creators, offering powerful computing capabilities for content creation.
  • High Fidelity Visuals
    Experience stunning visuals with a boost clock speed of 2640 MHz, 16 GB of GDDR6X SDRAM, and support for up to 4 monitors, allowing for a maximum external resolution of 7680 x 4320. The inclusion of NVIDIA DLSS 3 and NVIDIA RTX Video Super Resolution enhances image clarity and performance.
  • Robust Build Quality
    The video card boasts a durable construction with a metal backplate, lower RDS(on) MOSFETs, and screen cooling technology, ensuring longevity and reliability during intense gaming sessions.
Gigabyte GeForce RTX 4070 Ti SUPER EAGLE OC 16G - graphics card - GeForce RTX 4070 Ti Super - 16 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
NVIDIA GeForce RTX 4070 Ti SUPER
16 GB GDDR6X
Memory Speed
21 Gbps
Boost Clock
2640 MHz
CUDA Cores
8448
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
3 x DisplayPort , HDMI
API Supported
DirectX 12 Ultimate, OpenGL 4.6
5 cm x 26.1 cm x 12.6 cm
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Boost Clock
2640 MHz
CUDA Cores
8448
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
3D Active Fan, 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, 80mm Unique blade fan design, composite copper heat pipes, Dual Bios, Gigabyte Alternate Spinning, GIGABYTE WINDFORCE cooling design, GPU direct contact copper plates, Graphene Nano Lubricant, metal backplate, NVIDIA Ada Lovelace GPU technology, Nvidia Broadcast, NVIDIA DLSS 3, NVIDIA Reflex, NVIDIA RTX Video Super Resolution, Nvidia Studio, Optical Flow Accelerator, RGB fusion, screen cooling, Triple Fan Design, large copper plate, LED indicator, lower RDS MOSFETs
Size
16 GB
GDDR6X SDRAM
Memory Speed
21 Gbps
Bus Width
256-bit
Required Power Supply
750 W
Additional Requirements
16 pin PCI Express power connector
16-pin to 2x 8-pin power adapter
Software Included
NVIDIA GeForce Experience, Gigabyte Control Center
DisplayPort 1.4a
5 cm
26.1 cm
12.6 cm
