The GIGABYTE GeForce RTX 4070 Ti SUPER AERO OC 16G graphics card is designed to deliver an exceptional gaming and creative experience. It features a powerful NVIDIA GeForce RTX 4070 Ti SUPER graphics processor and 16 GB of GDDR6X SDRAM, making it capable of running demanding games and applications with ease. The card's advanced cooling system, which includes the GIGABYTE WINDFORCE cooling design, triple fan setup, and heat pipe direct touch technology, ensures it remains cool under pressure, allowing for sustained performance.
With support for DirectX 12 Ultimate and OpenGL 4.6, the card is prepared for next-generation games and software. It also supports up to 4 monitors, providing ample screen real estate for immersive gaming setups or productive multitasking. The inclusion of NVIDIA's technologies like DLSS 3, Reflex, and Broadcast enhances gaming, streaming, and content creation, making it a versatile choice for gamers and creators alike. Its robust build quality, featuring a metal backplate and anti-sag bracket, ensures durability and longevity, making it a wise investment for any serious PC builder or gamer.
Enhanced cooling technology
The GIGABYTE GeForce RTX 4070 Ti SUPER AERO OC 16G features the GIGABYTE WINDFORCE cooling design, incorporating 90mm unique blade fan design, heat pipe direct touch technology, and screen cooling to ensure optimal performance under heavy loads. -
Advanced gaming features
Equipped with NVIDIA Ada Lovelace GPU technology, NVIDIA DLSS 3, and NVIDIA Reflex, this graphics card delivers a responsive and immersive gaming experience. The inclusion of Nvidia Broadcast and Nvidia Studio further enhances streaming and content creation. -
Superior connectivity
With support for up to 4 monitors and a variety of output ports including 3 x DisplayPort and HDMI, the card offers flexible connectivity options for a multi-display setup. The inclusion of DisplayPort 1.4a standards ensures compatibility with displays. -
Robust build quality
The card's durability is ensured through features like a metal backplate, vented backplate, and the use of lower RDS MOSFETs. The anti-sag bracket and large copper plate provide additional support and heat dissipation, maintaining the card's longevity. -
High-performance memory
With a 256-bit memory interface and 16 GB of GDDR6X SDRAM, this graphics card is built to handle demanding games and applications. A memory speed of 21 Gbps allows for smooth and fast data processing.
- Gigabyte GeForce RTX 4070 Ti SUPER AERO OC 16G - graphics card - GeForce RTX 4070 Ti Super - 16 GB
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- NVIDIA GeForce RTX 4070 Ti SUPER
- Memory
- 16 GB GDDR6X
- Memory Speed
- 21 Gbps
- Core Clock
- 2655 MHz
- CUDA Cores
- 8448
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- 3 x DisplayPort , HDMI
- API Supported
- DirectX 12 Ultimate, OpenGL 4.6
- 5.76 cm x 30 cm x 12 cm
- 3-year warranty
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- Core Clock
- 2655 MHz
- CUDA Cores
- 8448
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- 3D Active Fan, 3rd gen Tensor Cores, 4th gen Tensor Cores, 90mm Unique blade fan design, Dual Bios, Gigabyte Alternate Spinning, GIGABYTE WINDFORCE cooling design, Graphene Nano Lubricant, metal backplate, NVIDIA Ada Lovelace GPU technology, Nvidia Broadcast, NVIDIA DLSS 3, NVIDIA Reflex, NVIDIA RTX Video Super Resolution, Nvidia Studio, Optical Flow Accelerator, RGB fusion, screen cooling, Triple Fan Design, vented backplate, composite copper heat pipes, Heat Pipe Direct Touch technology, lower RDS MOSFETs, GPU direct contact copper plates, large copper plate
- Size
- 16 GB
- Technology
- GDDR6X SDRAM
- Memory Speed
- 21 Gbps
- Bus Width
- 256-bit
- Required Power Supply
- 750 W
- Additional Requirements
- 16 pin PCI Express power connector
- Included Accessories
- 16-pin to 2x 8-pin power adapter, anti-sag bracket
- Software Included
- NVIDIA GeForce Experience, Gigabyte Control Center
- DisplayPort 1.4a
- 5.76 cm
- 30 cm
- 12 cm
- Limited warranty - 3 years
