The GIGABYTE GeForce RTX 4070 SUPER WINDFORCE OC 12G video card is designed to deliver an exceptional gaming experience. It is powered by NVIDIA's GeForce RTX 4070 SUPER graphics processor and features 12 GB of GDDR6X SDRAM, making it capable of running high-resolution games smoothly at 7680 x 4320 resolution. The card's cooling system, which includes a triple fan design, composite copper heat pipes, and the GIGABYTE WINDFORCE technology, ensures that it remains cool even during intense gaming sessions.
In addition to its impressive cooling capabilities, the video card comes equipped with a range of features designed to enhance gaming performance. These include NVIDIA Ada Lovelace GPU technology, 3rd gen Ray Tracing Cores, and 4th gen Tensor Cores, which work together to deliver realistic lighting and AI-accelerated graphics. The card also supports DirectX 12 Ultimate and OpenGL 4.6, ensuring compatibility with a wide range of games and applications. With its robust build and innovative technologies, the GIGABYTE GeForce RTX 4070 SUPER WINDFORCE OC 12G is a choice for gamers looking to elevate their gaming experience.
Advanced cooling
The GIGABYTE GeForce RTX 4070 SUPER WINDFORCE OC 12G features the GIGABYTE WINDFORCE cooling design, incorporating 80mm unique blade fan design, triple fan setup, and composite copper heat pipes to ensure optimal cooling performance under intense gaming sessions. -
Exceptional graphics
Equipped with NVIDIA GeForce RTX 4070 SUPER and supported by NVIDIA Ada Lovelace GPU technology, 3rd gen Ray Tracing Cores, and 4th gen Tensor Cores, this video card delivers stunning visuals, realistic lighting, and AI-accelerated performance for a breathtaking gaming experience. -
High-speed memory
With a 192-bit bus width and 12 GB of GDDR6X SDRAM, the video card achieves a memory speed of 21 Gbps, enabling faster load times, high-resolution textures, and smooth gaming at 7680 x 4320 resolution. -
Enhanced durability
The card's durability is enhanced with features like a metal backplate, lower RDS(on) MOSFETs, and Graphene Nano Lubricant, ensuring long-term reliability and stability during high-performance gaming. -
Innovative technology
Features such as NVIDIA DLSS 3, NVIDIA RTX Video Super Resolution, and NVIDIA Reflex enhance gaming and creative work, offering improved frame rates, video enhancement, and low latency for competitive gaming.
- Gigabyte GeForce RTX 4070 SUPER WINDFORCE OC 12G - graphics card - GeForce RTX 4070 Super - 12 GB
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- NVIDIA GeForce RTX 4070 SUPER
- Memory
- 12 GB GDDR6X
- Memory Speed
- 21 Gbps
- Core Clock
- 2505 MHz
- CUDA Cores
- 7168
- Memory Interface
- 192-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- 3 x DisplayPort ¦ HDMI
- API Supported
- DirectX 12 Ultimate, OpenGL 4.6
- 5 cm x 26.1 cm x 12.6 cm
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- Core Clock
- 2505 MHz
- CUDA Cores
- 7168
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, GIGABYTE WINDFORCE cooling design, metal backplate, NVIDIA Ada Lovelace GPU technology, NVIDIA DLSS 3, Nvidia Broadcast, NVIDIA Reflex, NVIDIA RTX Video Super Resolution, Nvidia Studio, Optical Flow Accelerator, 80mm Unique blade fan design, 3D Active Fan, composite copper heat pipes, Gigabyte Alternate Spinning, Graphene Nano Lubricant, Heat Pipe Direct Touch technology, lower RDS MOSFETs, screen cooling, vented backplate, Triple Fan Design
- Size
- 12 GB
- Technology
- GDDR6X SDRAM
- Memory Speed
- 21 Gbps
- Bus Width
- 192-bit
- Required Power Supply
- 700 W
- Additional Requirements
- 16 pin PCI Express power connector
- Included Accessories
- 16-pin to 2x 8-pin power adapter
- Software Included
- NVIDIA GeForce Experience, Gigabyte Control Center
- DisplayPort 1.4a
- 5 cm
- 26.1 cm
- 12.6 cm
