Say hello to the latest in NVIDIA's 40-Series Graphics Cards, with the Gigabyte GeForce RTX 4060 WINDFORCE OC. It’s powered by the NVIDIA Ada Lovelace architecture and comes with 8GB of GDDR6 memory to deliver the ultimate experience for gamers and creators, bringing with it all new streaming multi-processors, 4th Gen Tensor Cores and 3rd Gen RT Cores, allowing you to experience an enormous leap in performance, efficiency and AI-powered graphics. Featuring the renowned Windforce cooling system, comprised of a capable 2x 80mm unique bladed fans with alternate spin technology, screen and 3D active technology cooling to keep all that performance in check. Utilise the incredible RGB fusion technology along with the Gigabyte control center, to customise the subtle lighting to suit your style, plus With dual bios, protective metal backplate and an ultra-durable design you can propel yourself into the future with Gigabyte.
WINDFORCE cooling system
The WINDFORCE cooling system features three 80 mm unique blade fans, alternate spinning, composite copper heat pipes that directly touch the GPU, 3D active fans and screen cooling, which together provide high efficiency heat dissipation. -
Alternate spinning
Reduce the turbulence of adjacent fans and increase airflow pressure. -
3D Active Fan
The 3D Active Fan provides semi-passive cooling, and the fans will remain off when the GPU is in a low load or low power game. -
Unique blade fan
The airflow is split by the triangular fan edge, and guided smoothly through the 3D stripe curve on the fan surface. -
Graphene nano lubricant
Graphene nano lubricant can extend the life of sleeve bearing fan by 2.1 times, close to the life of double ball bearing, and is quieter. -
Optimized thermal module
The pure copper heat pipe makes direct contact with the GPU to facilitate enhanced heat transfer to the heatsink, optimizing the cooling efficiency of the graphics card. -
Screen cooling
Extended heatsink allows air to pass through, providing better heat dissipation. -
Protection back plate
The back plate not only provides an aesthetical shape, but also enhances the structure of the graphics card to provide complete protection. -
Dual bios
The factory default setting is OC mode, which provides users with good performance. However, switching to silent mode will enjoy a quieter experience. -
Ultra cooling
Lower RDS(on) MOSFETs are specially designed to produce lower switching resistance for faster electric current charging and discharging at extremely low temperature. -
Low power loss
Metal Choke hold energy much longer than common iron-core chokes at high frequency, thus effectively reduce core energy loss and EMI interference. -
Longer life
Lower ESR Solid Capacitors ensure better electronic conductivity for excellent system performance and longer lifespan. -
Friendly PCB design
Fully automated production process ensures top quality of the circuit boards and eliminates sharp protrusions of the solder connectors seen on the conventional PCB surface. This friendly design prevents your hands from getting cut or inadvertently damaging components when making your build. -
Power through the game
GIGABYTE offers the strong power supply solutions for your graphics cards. You can choose either the AORUS series or the UD series to power your graphics card. -
GIGABYTE control center
GIGABYTE control center is a unified software for all GIGABYTE supported products. It provides an intuitive interface that allows users to adjust clock speed, voltage, fan mode and power target in real-time.
- Gigabyte GeForce RTX 4060 WINDFORCE OC 8G - graphics card - GeForce RTX 4060 - 8 GB
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- NVIDIA GeForce RTX 4060 - up to
- Memory
- 8 GB GDDR6
- Memory Speed
- 17 Gbps
- Core Clock
- 2475 MHz
- CUDA Cores
- 3072
- Memory Interface
- 128-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- 2 x DisplayPort (version 1.4a) ¦ 2 x HDMI
- API Supported
- DirectX 12 Ultimate, OpenGL 4.6
- 4.1 cm x 19.2 cm x 12 cm
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- Core Clock
- 2475 MHz
- CUDA Cores
- 3072
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- 3D Active Fan, 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, composite copper heat pipes, Dual Fan Design, Gigabyte Alternate Spinning, GIGABYTE WINDFORCE cooling design, Graphene Nano Lubricant, Heat Pipe Direct Touch technology, NVIDIA Ada Lovelace GPU technology, Nvidia Broadcast, NVIDIA DLSS 3, NVIDIA Reflex, Nvidia Studio, screen cooling
- Size
- 8 GB
- Technology
- GDDR6 SDRAM
- Memory Speed
- 17 Gbps
- Bus Width
- 128-bit
- Required Power Supply
- 450 W
- Additional Requirements
- 8 pin PCI Express power connector
- Software Included
- Gigabyte Control Center
- 4.1 cm
- 19.2 cm
- 12 cm
