- Powered by NVIDIA DLSS 3, ultra-efficient Ada Lovelace arch, and full ray tracing
- 4th Generation Tensor Cores: Up to 4x performance with DLSS 3 vs. brute-force rendering
- 3rd Generation RT Cores: Up to 2X ray tracing performance
- Powered by GeForce RTX™ 4060 Ti (8GB)
- Integrated with 8GB GDDR6 128bit memory interface
- WINDFORCE cooling system
- RGB Fusion
- Dual BIOS
- Protection metal back plate
The WINDFORCE cooling system features three 80 mm unique blade fans, alternate spinning, 4 composite copper heat pipes directly touch the GPU, 3D active fans and screen cooling, which together provide high efficiency heat dissipation. -
The metal back plate not only provides an aesthetical shape, but also enhances the structure of the graphics card to provide complete protection. -
Dual BIOS
The factory default setting is OC mode, which provides users with the best performance. However, switching to silent mode will enjoy a quieter experience. -
Power indicator
When experiencing any power supply abnormality, the indicator will alert gamers by flashing light. -
Ultra Durable
Ultra Durable certified highest-grade metal chokes, lower ESR solid capacitors, copper PCB, and lower RDS (on) MOSFETs, plus over-temperature design to deliver superior performance and longer system life. -
Friendly PCB design
Fully automated production process ensures top quality of the circuit boards and eliminates sharp protrusions of the solder connectors seen on the conventional PCB surface. This friendly design prevents your hands from getting cut or inadvertently damaging components when making your build.
- Gigabyte GeForce RTX 4060 Ti GAMING OC 8G - graphics card - GeForce RTX 4060 Ti - 8 GB
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- NVIDIA GeForce RTX 4060 Ti
- Memory
- 8 GB GDDR6
- Memory Speed
- 18 Gbps
- CUDA Cores
- 4352
- Memory Interface
- 128-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- 2 x DisplayPort , 2 x HDMI
- API Supported
- DirectX 12 Ultimate, OpenGL 4.6
- 5.3 cm x 28.1 cm x 11.7 cm
- 3-year warranty
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- CUDA Cores
- 4352
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, Dual Bios, GIGABYTE WINDFORCE cooling design, metal backplate, NVIDIA Ada Lovelace GPU technology, RGB fusion, 3D Active Fan, Gigabyte Alternate Spinning, Nvidia Broadcast, NVIDIA DLSS 3, NVIDIA Reflex, Nvidia Studio, Graphene Nano Lubricant, Heat Pipe Direct Touch technology, screen cooling
- Size
- 8 GB
- Technology
- GDDR6 SDRAM
- Memory Speed
- 18 Gbps
- Bus Width
- 128-bit
- Required Power Supply
- 500 W
- Additional Requirements
- 8 pin PCI Express power connector
- Software Included
- Gigabyte Control Center
- DisplayPort 1.4a
- 5.3 cm
- 28.1 cm
- 11.7 cm
- Limited warranty - 3 years
