Gigabyte GeForce RTX 4060 Ti GAMING OC 16GB Graphics Card
Quicklinx: HVHDWS00 Mfr#: GV-N406TGAMING OC-16GD
Say hello to the latest in NVIDIA's 40-Series Graphics Cards, with the Gigabyte GeForce RTX 4060 Ti GAMING OC 16G. It’s powered by the NVIDIA Ada Lovelace architecture and comes with 16GB of GDDR6 memory to deliver the ultimate experience for gamers and creators, bringing with it all new streaming multi-processors, 4th Gen Tensor Cores and 3rd Gen RT Cores, allowing you to experience an enormous leap in performance, efficiency and AI-powered graphics. Featuring the renowned Windforce cooling system, comprised of 3x 80mm unique bladed fans with alternate spin technology, screen and 3D active technology cooling to keep all that performance in check. Utilise the incredible RGB fusion technology along with the Gigabyte control center, to customise the subtle lighting to suit your style, plus With dual bios, protective metal backplate and an ultra-durable design you can propel yourself into the future with Gigabyte.
  • WINDFORCE cooling system
    The WINDFORCE cooling system features three 80 mm unique blade fans, alternate spinning, 4 composite copper heat pipes directly touch the GPU, 3D active fans and screen cooling, which together provide high efficiency heat dissipation.
  • Alternate spinning
    Reduce the turbulence of adjacent fans and increase airflow pressure.
  • 3D Active Fan
    The 3D Active Fan provides semi-passive cooling, and the fans will remain off when the GPU is in a low load or low power game.
  • Unique blade fan
    The airflow is split by the triangular fan edge, and guided smoothly through the 3D stripe curve on the fan surface.
  • Graphene nano lubricant
    Graphene nano lubricant can extend the life of sleeve bearing fan by 2.1 times, close to the life of double ball bearing, and is quieter.
  • Heat pipes direct touch
    The shape of the pure copper heat pipe maximizes the direct contact area with the GPU. The heat pipe also covers the VRAM through a metal plate contact to ensure proper cooling.
  • Screen cooling
    Extended heatsink allows air to pass through, providing better heat dissipation.
  • RGB fusion
    With 16.7M customizable color options and numerous lighting effects, you can choose any lighting effect or synchronize with other devices in GIGABYTE control center.
  • Protection metal back plate
    The metal back plate not only provides an aesthetical shape, but also enhances the structure of the graphics card to provide complete protection.
  • Dual BIOS
    The factory default setting is OC mode, which provides users with good performance. However, switching to silent mode will enjoy a quieter experience.
  • Power indicator
    When experiencing any power supply abnormality, the indicator will alert gamers by flashing light.
  • Ultra durable
    Ultra durable certified high-grade metal chokes, lower ESR solid capacitors, 2oz copper PCB, and lower RDS(on) MOSFETs, plus over-temperature design to deliver superior performance and longer system life.
  • Friendly PCB design
    Fully automated production process ensures top quality of the circuit boards and eliminates sharp protrusions of the solder connectors seen on the conventional PCB surface. This friendly design prevents your hands from getting cut or inadvertently damaging components when making your build.
  • Power through the game
    GIGABYTE offers the strong power supply solutions for your graphics cards. You can choose either the AORUS series or the UD series to power your graphics card.
  • GIGABYTE control center
    GIGABYTE control center is a unified software for all GIGABYTE supported products. It provides an intuitive interface that allows users to adjust clock speed, voltage, fan mode and power target in real-time.
Gigabyte GeForce RTX 4060 Ti GAMING OC 16G - graphics card - GeForce RTX 4060 Ti - 16 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
NVIDIA GeForce RTX 4060 Ti
16 GB GDDR6
Memory Speed
18 Gbps
Core Clock
2595 MHz
CUDA Cores
4352
Memory Interface
128-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
2 x DisplayPort , 2 x HDMI
API Supported
DirectX 12 Ultimate, OpenGL 4.6
5.3 cm x 28.1 cm x 11.7 cm
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Core Clock
2595 MHz
CUDA Cores
4352
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
3rd gen Ray Tracing Cores, 4th gen Tensor Cores, Dual Bios, GIGABYTE WINDFORCE cooling design, metal backplate, NVIDIA Ada Lovelace GPU technology, 3D Active Fan, Gigabyte Alternate Spinning, Nvidia Broadcast, NVIDIA DLSS 3, NVIDIA Reflex, Nvidia Studio, Heat Pipe Direct Touch technology, screen cooling, Graphene Nano Lubricant, RGB fusion
Size
16 GB
GDDR6 SDRAM
Memory Speed
18 Gbps
Bus Width
128-bit
Required Power Supply
500 W
Additional Requirements
8 pin PCI Express power connector
Software Included
Gigabyte Control Center
DisplayPort 1.4a
5.3 cm
28.1 cm
11.7 cm
