Say hello to latest iteration in NVIDIAs GeForce 40-Series graphics cards, with the Gigabyte GeForce RTX 4060Ti Eagle OC. It’s powered by the NVIDIA Ada Lovelace architecture and comes with 8GB of GDDR6 memory to deliver the ultimate experience for gamers and creators, bringing with it all new streaming multi-processors, 4th Gen Tensor Cores and 3rd Gen RT Cores, allowing you to experience an enormous leap in performance, efficiency and AI-powered graphics. Featuring the renowned Windforce cooling system, comprised of 3x 80mm unique bladed fans with alternate spin technology, screen and direct touch cooling to keep all that performance in check. Utilise the incredible Gigabyte control center that allows users to adjust clock speed, voltage, fan mode and power target in real-time. plus With dual bios, protective metal backplate and an ultra-durable design you can propel yourself into the future with Gigabyte.
WINDFORCE cooling system
The WINDFORCE cooling system features three 80 mm unique blade fans, alternate spinning, 3 composite copper heat pipes directly touch the GPU, 3D active fans and screen cooling, which together provide high efficiency heat dissipation. -
Protection back plate
The back plate not only provides an aesthetical shape, but also enhances the structure of the graphics card to provide complete protection. -
Dual BIOS
The factory default setting is OC mode, which provides users with the best performance. However, switching to silent mode will enjoy a quieter experience. -
Ultra Durable
Ultra Durable certified highest-grade metal chokes, lower ESR solid capacitors, copper PCB, and lower RDS (on) MOSFETs, plus over-temperature design to deliver superior performance and longer system life. -
Friendly PCB design
Fully automated production process ensures top quality of the circuit boards and eliminates sharp protrusions of the solder connectors seen on the conventional PCB surface. This friendly design prevents your hands from getting cut or inadvertently damaging components when making your build.
- Gigabyte GeForce RTX 4060 Ti EAGLE OC 8G - graphics card - GeForce RTX 4060 Ti - 8 GB
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- NVIDIA GeForce RTX 4060 Ti - up to
- Memory
- 8 GB GDDR6
- Memory Speed
- 18 Gbps
- Core Clock
- 2550 MHz
- CUDA Cores
- 4352
- Memory Interface
- 128-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- 2 x DisplayPort , 2 x HDMI
- API Supported
- DirectX 12 Ultimate, OpenGL 4.6
- 4.1 cm x 27.2 cm x 11.5 cm
- 3-year warranty
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- Core Clock
- 2550 MHz
- CUDA Cores
- 4352
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, Dual Bios, GIGABYTE WINDFORCE cooling design, metal backplate, NVIDIA Ada Lovelace GPU technology, 3D Active Fan, Gigabyte Alternate Spinning, Nvidia Broadcast, NVIDIA DLSS 3, NVIDIA Reflex, Nvidia Studio, Heat Pipe Direct Touch technology, screen cooling, Graphene Nano Lubricant
- Size
- 8 GB
- Technology
- GDDR6 SDRAM
- Memory Speed
- 18 Gbps
- Bus Width
- 128-bit
- Required Power Supply
- 500 W
- Additional Requirements
- 8 pin PCI Express power connector
- Software Included
- Gigabyte Control Center
- DisplayPort 1.4a
- 4.1 cm
- 27.2 cm
- 11.5 cm
- Limited warranty - 3 years
